What is that noise???
Results 1 to 10 of 10
Like Tree5Likes
  • 2 Post By admiral
  • 2 Post By scotti158
  • 1 Post By Fred
Thread: What is that noise???
    Senior Member rastaman's Avatar
    Jun 2011
    Florida
    147
    On my 1999 Tw there is a rattling noise, at first I thought it had to be the heat deflector on the exhaust, but it wasn't....after much searching it seams to be coming from down by the starter,,,or it sounds that way...its a rattling type of noise. This bike has always seems to do it, so I wasn't overly concerned. However now my 2003 is with 5k miles on it is starting to do it some time.
    any ideas???
    thanks
    Senior Member peter's Avatar
    Jul 2011
    Providenciales, Turks & Caicos
    398
    You may have one (or two) of the "clunkers". There is a thread here somewhere. Both, my 2010 & 2009 are "clunkers". Those of us who have them, we don't worry and just happily clunker along
    Jun 2011
    Florida
    147
    Quote Originally Posted by TWilight View Post
    Engine gravel shield loose ? Some rocks or gravel caught up in the engine gravel shield ?
    I checked that ...not the gravel shield
    Jun 2011
    Florida
    147
    Quote Originally Posted by peter View Post
    I thought the clunkers made a noise a noise in the handle bars ...a clunking noise....my noise is a rattle
    Frosty Hollow
    13,046
    Could be lots of things.
    Like you I had a rattling noise for about a year. Finally discovered one of my upper motor mount bolts was loose. Yep, that was the rattle. Later I had another rattle, this time it was a stone rattling around up there. Moral of the story, check for loose bolts.
    Also thinking possible cam chain loose. 1999 has a manual tensioner, but the 2003 is auto. Most likely not the noise on the 2003, but worth mentioning.
    And the engines do have a unique "not quiet" sound as well, but first I'd spend the time checking for external lose bolts and such. Other will have some other good idea's too.
    wolfy and TWilight like this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    It is one of the few downsides of a TW. They are prone to making very scary noises that are very hard to locate and identify.
    Fortunately, most of them are just noises, but the scary part is not knowing if they can safely be ignored.
    Phelonius
    May 2013
    Groton, NY
    2,663
    When I worked as a Yamaha mechanic, the Regional Service Rep would come around to instruct us on new model procedure, tech bulletins, etc. We weren't supposed to refer to normal "noises" as noises. We were to refer to them as "sounds". Apparently, to soothe concerned customers about a "noisy" bike. This wasn't one of his better tips!
    Fred and Purple like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Feb 2013
    Missoula, MT
    908
    Yes, check those top engine mounts. Mine ('95 TW) was loose after only 300 miles post top-end rebuild. I KNOW I tightened them enough when motor was installed. Tighten everything else while you are at it. I actually lost a muffler mounting bolt one day.
    And, if you have not, adjust the cam chain tensioner.
    18,711
    Nice to learn my TW doesn't make noises, just sounds.
    Did Regional Service Rep mention how to have these TWs make power or money?
    scotti158 likes this.
    May 2013
    Groton, NY
    2,663
    No power making tips. Buy low and sell high for the money making.
    2013 Yamaha TW200
    1996 Yamaha TW200
  1. Ticking Noise
    By lowtechboy in forum Technical Help
    Last Post: 01-02-2017, 03:07 PM
  2. Final drive noise?
    By dabsdog in forum Technical Help
    Last Post: 08-05-2014, 12:42 PM
  3. Identify this noise
    By freerider in forum Technical Help
    Last Post: 07-25-2014, 06:51 PM
  4. Weird noise on my new TW
    By Holdnon72 in forum General Discussion
    Last Post: 01-20-2014, 06:36 PM
  5. Weird Noise
    By wvhunter in forum Technical Help
    Last Post: 04-23-2011, 08:13 PM
