Is my chain too loose?
Results 1 to 10 of 13
Like Tree20Likes
Thread: Is my chain too loose?
    Junior Member Olaf's Avatar
    Aug 2015
    Austin, TX
    14
    Howdy folks,
    I have a new 2015 TDub, and just passed the 200 mile mark. I noticed that my chain might be a little loose, so I consulted the owner's manual. The recommended slack according to the manual is between 1.4 and 2.4 inches. The slack on my chain is about 2.75 inches. Is this something that should concern me, or am I good to just wait for the 600-mile service and let Yamaha adjust the chain at that point? Recommendations?
    Thanks.
    Skiing the slopes in Switzerland
    17,588
    Adjust it.
    Hoot Gibson and Peterb like this.
    1st John 1:9
    John 3:16
    John 3:17
    May 2014
    Yooper, MI
    1,510
    Adjust it.
    NOW, or sooner, which ever occurs first.
    Aug 2015
    Austin, TX
    14
    Wow after reading through the manual I didn't realize how easy it is to adjust. No brainer.
    littletommy likes this.
    17,588
    If you're keeping the stock chain, just consider it practice, you'll be adjusting it a lot. (sorry, couldn't help it)
    Hoot Gibson and Dryden-Tdub like this.
    1st John 1:9
    John 3:16
    John 3:17
    May 2013
    Groton, NY
    2,663
    LT is right, the stock chain wears very quickly. Get an O-Ring or better yet, an X-Ring type chain on it as as possible, before it starts to wear the sprockets. Less adjusting + less wear on sprockets=more riding for less $. I installed an X-ring chain and it went 4,000 miles before the first adjustment!
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    6,999
    A little to loose is much much better than a little to tight.
    My chain is loose as in floppy loose. It has never given me trouble.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    Quote Originally Posted by scotti158 View Post
    +1 on the O or X ring!
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    Mar 2015
    Ynys Môn
    4,637
    Get used to lifting the chain with the toe of your boot to check the tension before you ride – you’ll soon get to know if it gets too tight or too loose – it’s a good way to check if it needs lube too
    The chain is the highest maintenance item on the TW (or any) bike – even if it only needs adjusting once a month – you need to know where it is at any given time
    As suggested above – an “X” ring or “O ring chain will make those adjustments few and far between – but still – get your boot up there every now and then just in case ………
    - Hidden Content
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Adjust it.
    Scotti......what brand of X- ring chain did you buy?.
  1. Replies: 7
    Last Post: 01-26-2015, 09:55 PM
  2. Loose shifter
    By tcepilot in forum Technical Help
    Last Post: 11-10-2014, 10:50 PM
  3. tappet nut came loose
    By greendub in forum Technical Help
    Last Post: 04-29-2013, 09:32 PM
  4. Loose chain all of a sudden?
    By nfpgasmask in forum General Discussion
    Last Post: 10-11-2012, 11:51 AM
