Carb bowl vent clogged
Results 1 to 10 of 10
Like Tree4Likes
  • 3 Post By Azxj91
  • 1 Post By Azxj91
Thread: Carb bowl vent clogged
    Senior Member Azxj91's Avatar
    Feb 2015
    Tucson, AZ
    154
    Hello all.....
    My poor TW hasn't been running too good..
    I pulled carb out planning to follow the excellent lazy cleaning thread. But found that the rubber line from bowl vent on bottom of carb was plugged with mud. Would this blockage cause my issues??. Or should I open up the carb?
    History.
    2007.. I bought it 6 months ago with about 870 miles, about 1600 now. Previous owner bought from estate sale, rode it around the block and decided to sell and get a street bike. Was running nice until couple weeks ago.
    Best description is it misses, stumbles or feels like running out of gas at mid to full throttle. Most noticeable in 4th and 5th gear, but can feel it in all gears. Starts and idles fine. And seems fine as long as dont rev it much. Gets better if I pull the choke out when it stars to stumble. But then has high/poor idle.
    Checked air filter and plug.
    Been running sea foam to see if will clean it out.
    I checked/ adjusted valves at about 900 miles. ( maybe should check to make sure the haven't loosened?)
    Fresh oil and Lzrd cooler.
    thanks.....
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Clean the vent tube, it needs to breathe! May very well cure your issues.
    Feb 2015
    Tucson, AZ
    154
    Ok thanks! I will put carb back in and test it before attempting the carb cleaning.
    Feb 2015
    Tucson, AZ
    154
    Put the carb back in and rode it . No change. So going to pull it back out and proceed with a cleaning.
    Feb 2015
    Tucson, AZ
    154
    Fixed!!,! I think. Need longer test ride to be sure. Cleaned some gunk from the bowl, the main and pilot jets.. Looked almost like 2 pieces of tiny insect legs.. And some floaty stuff. Quick ride around the block, noticeable power increase and no stumble!!! Wouldn't have attempted to open the carb at all without the excellent write up on here!!,
    Thanks all!!!
    littletommy, Mel and admiral like this.
    Feb 2015
    Tucson, AZ
    154
    Next project is to try and install my new front tire!!
    littletommy likes this.
    Vacationing in the Bahama's
    17,580
    Good job bro.
    1st John 1:9
    John 3:16
    John 3:17
    Nov 2010
    Frostbite Falls Ill
    2,719
    You have been riding without the front wheel?
    Phelonius
    Feb 2015
    Tucson, AZ
    154
    Haha... That's well beyond my skill level!
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Good trouble shooting . Glad it's running.
  1. TW died on water crossing - Carb Vent solution offered
    By vuldub in forum Technical Help
    Last Post: 11-08-2019, 08:31 PM
  2. Is this engine oil coming out of my carb vent tube?
    By Holdnon72 in forum Technical Help
    Last Post: 06-24-2014, 09:46 PM
  3. Replies: 17
    Last Post: 02-07-2014, 10:42 AM
  4. 1990 TW 200 Carb Vent lines?
    By sasnydley in forum Technical Help
    Last Post: 03-15-2011, 08:00 AM
  5. Carb float bowl screws
    By jbfla in forum Technical Help
    Last Post: 10-05-2010, 03:57 PM
clogged float bowl vent
plugged bowl vent
