Need a new oil drain plug...
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By JS5owner
Thread: Need a new oil drain plug...
    Senior Member RDW's Avatar
    Nov 2013
    Oregon
    178
    Is it specific to the bike or can I use any drain plug that is the correct diameter (which by the way, I don't know because I have not yet be able to remove the existing plug).
    Thanks,
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    the plug looks specific to this motor as it has a slot for the spring and screen to sit in when the plug is installed
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Nov 2013
    Oregon
    178
    Thanks. Do you have a recommendation for a mail order store that carries them?
    Quote Originally Posted by grewen View Post
    Senior Member AGman's Avatar
    Nov 2013
    159
    Partshark are one option. Put a socket on the plug (19mm) and give it a belt with a hammer, usually helps. Order a new O'ring too...
    A single hex socket helps to not damage the cap too.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Just don't booger it, They are delicate. And fie upon you if you cross thread it putting it back on.
    Phelonius
    May 2014
    Yooper, MI
    1,510
    Sometimes it's cheaper to just get the parts numbers and search on Google. Most online motorcycle parts stores rape on shipping and handling.
    5H0-15351-00-00 PLUG, DRAIN
    93210-347A1-00 O-RING
    Amazon.com: Yamaha 5H0153510000 Oil Pump Drain Plug: Automotive
    Nov 2013
    Oregon
    178
    >Just don't booger it, They are delicate.<
    Too late; the deal went down :-)
    I want the new one on hand when I finally get the other one off.
    Thanks everyone for your suggestions!
    Senior Member JS5owner's Avatar
    Palm Springs / Desert Hot Springs
    308
    ZDR1 likes this.
    2007 TW "Muley": Cyclerack rear, 55 tooth rear sprocket, Duro Power Grip & Shinko SR241, Clarke tank, Ricochet bash plate, Mule hitch pin quick seat removal, Trail Tech Vapor w/ Dashboard, hardwired Garmin 60csx & 205w, 12vdc adaptor, independent high beam off/on and signal beeper, modified seat.
    2000 Yamaha V-star 650 Custom - [sold]
    2009 Yamaha WR250R - "Willie Boy" the slimmer faster brother of my Muley.
    2009 Hidden Content . Wow, what fun on the highway!
    Nov 2013
    Oregon
    178
    Can anyone tell me if the o-ring is something special (to withstand heat) or can I just pick one up at the hardware store/auto parts store?
    Thanks!
  1. Drain plug stuck
    By georgeDubya in forum Technical Help
    Last Post: 02-04-2016, 07:23 PM
  2. MAGNETIC DRAIN PLUG
    By 1nonly in forum General Discussion
    Last Post: 05-04-2012, 08:39 PM
  3. Drain plug rounded off
    By chipyting in forum Technical Help
    Last Post: 04-15-2012, 04:26 AM
  4. another tw another stipped drain plug
    By triple3jrb in forum Technical Help
    Last Post: 03-07-2012, 03:42 PM
  5. wtb OIL DRAIN PLUG
    By rvtjonny in forum TW200 Classifieds
    Last Post: 02-06-2012, 08:35 PM
5h0153510000 oil pump drain plug
