2009 tw200 clutch shudder at partial engagement
Results 1 to 4 of 4
    Junior Member gravelhack's Avatar
    Sep 2015
    7
    Just bought this TW200. 340lb. rider. Upsized the rear sprocket to 55. Warm engine, Feathering the clutch while trail riding causes a loud chatter with shudder and slipping under partial engagement while moving ahead from a stop or low speed. Thought it might be wrong oil used by previous owner. Drained oil looked clean, not burnt. Refilled with silkolene pro 4 10w40. Havent had a chance to try it. Return spring OK and adjusted. Basically shudders at engagement.
    Hailey, ID
    3,404
    Nope, not the oil. Clutch springs and/or clutch plates need replacing.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Sep 2015
    7
    Just seemed odd. No sign or sound of chatter prior to todays slow tight woods shakedown ride. I was only into it maybe 1/2 hr when engagement noise began. Only 3100 miles on odom. no noise after cool down as far as I can tell. Might just have to face the music and do a clutch. Is there a clutch suited better to heavier loads than the OEM Yamaha??
    Hailey, ID
    3,404
    Hmmm, maybe the spring bolts got loose. Yes, there are stronger springs available, lots of threads about that in here. Have a look at page C3 in the parts catalog: http://www.yamaha-motor.com.mx/manua.../5fyg_2003.pdf
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Clutch engagement, smoothness etc
    By stephenmarklay in forum Technical Help
    Last Post: 07-24-2019, 09:59 PM
  2. Why I like the 5 speed gearing of the TW and the Far out clutch engagement
    By dogonit in forum Performance and Customization
    Last Post: 06-13-2015, 12:28 PM
  3. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 07:24 AM
  4. Spoke set (partial) for sale
    By Boyitgobob in forum TW200 Classifieds
    Last Post: 11-28-2013, 10:47 AM
  5. 1987 TW200 for sale, SE Wisc - partial trades?
    By windingroads in forum TW200 Classifieds
    Last Post: 09-28-2013, 10:33 PM
2009 tw200 clutch plates
