TW air filter oil
Results 1 to 10 of 14
Like Tree14Likes
Thread: TW air filter oil
    Senior Member Explorer's Avatar
    Aug 2014
    Hailey, ID & Sedona, AZ
    115
    TW air filter oil
    I have a 2014 and recently washed out the air filter. The Owners Manual states that the air filter needs to be oiled. I have not done this, but the TW seems to run fine. Is there any damage or ramification of running the bike without air filter oil? I assume it might run leaner??
    Thanks to anyone and everyone that might help.
    Explorer
    Frosty Hollow
    13,174
    Without the oil, it's possible some fine dirt and debris can make it through the air filter and into the carburetor where it could collect in the float bowl and clog needed passageways, jets etc.
    littletommy likes this.
    Senior Member jb882's Avatar
    Aug 2013
    1,376
    The oil is what catches the small particles of dirt and dust and keep them out of your engine. A foam filter is not like a paper one and should not be run dry. I would oil that thing before you ride it any more.
    I personally like the no toil stuff that pro cycle and others sell. just wear rubber gloves when you oput the oil on, its goopy stuff.
    https://www.rockymountainatvmc.com/p...Air-Filter-Oil
    https://www.rockymountainatvmc.com/p...Filter-Cleaner
    Fred likes this.
    Aug 2014
    115
    Thanks guys. I went & bought the oil & applied it. I wonder if it runs richer (fuel) with an oiled air filter as less air gets in?
    Glad we have this Forum to get sound advice!
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,403
    Quote Originally Posted by Explorer View Post
    e!
    It shouldn't, if you have the proper amount of oil.
    There should only be a thin film of oil on the filter, not dripping wet.
    Squeeze out all the oil you can.
    jb
    littletommy and admiral like this.
    May 2014
    Yooper, MI
    1,510
    Frame makes some in a spray can. Much less mess and waste. Pretty orange color so you can see you're covered.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    In the olden days it might also have said to use 30wt motor oil. I had some 90wt on the shelf and I noticed it was quite sticky/gooy. Takes a couple of minutes to work it in but a little dab will do ya.
    It's my official foam filter oil now.
    best regards & God Bless
    MAC
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    19,073
    I use a K&N aerosol filter oil, nice red color. Once applied I squeeze all excess out between absorbent towels or paper waste until no more can be readily removed.
    admiral likes this.
    Frosty Hollow
    13,174
    I think Lizrdbrth mentioned 2-stroke oil a long time ago. I've been using that for the air filter squeezing out the excess just like you do with the K&N filter oil. The 2-stroke oil is a blueish color so that's how I can tell the entire filter is covered.
    @ Turtle Chaser. I've never heard of using these types of oil before. Good to know in case I don't have the filter oil or 2-stroke oil on hand. Sounds like many many ways to get this done.
    Turtle Chaser likes this.
    Senior Member TWROG's Avatar
    Dec 2014
    Stockbridge GA
    807
    Ive never used anything other than regular ol engine oil on any sponge filter. No particular weight, just whatever bottle happens to be open at the time.
    2009 TW200 "Cracker" - His fun ADV bike
    2006 TW200 "Blue" - Her fun ADV bike
    2011 XL1200X "48" - My cool bike
    1977 KZ650 - My vintage sport bike
  1. Air filter is dry...
    By nunya in forum Technical Help
    Last Post: 10-06-2014, 11:22 AM
  2. Oil Filter
    By Wingnut in forum Technical Help
    Last Post: 08-28-2013, 07:39 PM
  3. Oil filter
    By cat 4 life in forum Technical Help
    Last Post: 06-17-2013, 09:11 AM
  4. OEM Oil Filter
    By TWisty in forum Technical Help
    Last Post: 06-12-2012, 09:08 PM
  5. Old oil filter
    By Lido in forum Technical Help
    Last Post: 09-11-2011, 11:14 AM
