TUU Value Adjustment?
Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By Blueduce
Thread: TUU Value Adjustment?
    Senior Member Explorer's Avatar
    Aug 2014
    Hailey, ID & Sedona, AZ
    115
    I have a '14 with 2400 miles on it (bought it new). I was wondering if and when I should consider a valve adjustment? I DON'T hear any clicking, which I usually associate with values. Is there a general rule as to how often (miles), a TUU needs a value adjustment? I tend to err on the side... if it ain't broke, don't screw with it. Just want to make sure.
    Thanks
    Mar 2011
    Gobles, michigan
    1,826
    After the first 500.. Mine didn't require an adjustment..Then every 5,000..... I find the harder you rev. them the more out they become....OMM.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    Quote Originally Posted by Explorer View Post
    I DON'T hear any clicking, which I usually associate with values. I tend to err on the side... if it ain't broke, don't screw with it. Just want to make sure.
    Thanks
    Explorer, I've adjusted mine a few times now and at least once, maybe twice I had a tight valve! So I would vote to check them sooner rather than later. Just be sure your Tdub is completely cold, as in overnight.
    best regards and God Bless
    MAC
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    Senior Member Blueduce's Avatar
    Sep 2014
    Central valley Ca.
    209
    Great question explorer; *I have a 14 as well w/ 2000 miles and have adjusted the valves twice, the first time totally by the numbers & marks. Sounded like an old underwood Typewriter. My question , since the exhaust valve is closed for about 270 deg, why is it so important to hit the exact mark, *I mean, is it " more closed " at that exact mark? I think not. I have no desire to do any damage to my engine, but I don't think I need to be so top-dead-anal when my feeler gauge reads the same through most of the closed rotation. Please, if I'm missing something let me know....
    Dryden-Tdub and Peterb like this.
    "Cycles is a mean toy lady" Halsy Knox
    Senior Member dogonit's Avatar
    Aug 2014
    south central Va.
    656
    Hi Explorer: Give it a check, according to the manual sooner than you have, but after the first check(adjustment) you should be ready to ride for a serious bit of time without worrying. Oh, and by the way, how's the exploring going.? I like the fact that you actually ride it regularly. While I have a bit over 3K on mine, and not more given my other bikes, I think you know that you don't have to baby it. Ride it and enjoy and take care in the outback.
    Just give me a minute while I collect my thoughts. They're around here somewhere. Maybe!
    2013 TW200(Protaper SE ATV High handlebars, DID 428VX-X ring chain, Shinko Tires, K&N Air Filter, Seat Concepts "Grip" seat covering, Outlaw Racing Folding
    Gear shifter, My custom( long/thin) foot pegs, My custom(extended) Rear brake lever, Battery tender harness, Gel Battery, "Bikini" Bike rack, Mobil 1 4T synthetic, BLUE Ricochet Skid Plate , DG Exhaust & 15 Front Sproket.
  1. clutch adjustment?
    By Jmelarchy in forum Technical Help
    Last Post: 09-06-2014, 12:59 PM
  2. Need help with chain adjustment...
    Last Post: 04-05-2014, 11:08 PM
  3. Clutch Adjustment
    By Braden in forum Technical Help
    Last Post: 10-05-2013, 03:00 PM
  4. Valve adjustment(s)
    Last Post: 06-26-2013, 03:50 PM
  5. Cam Chain Adjustment
    By Eyesell in forum Technical Help
    Last Post: 07-28-2012, 08:05 PM
