Hard time getting into first some times.
Results 1 to 10 of 14
Like Tree28Likes
Thread: Hard time getting into first some times.
    Member Yamahauln's Avatar
    Sep 2015
    Ohio
    58
    I just purchase my TW last week, it's a 2015 I purchased with 78 miles. The bike is fantastic, I wouldn't want any other bikes honestly; however, sometimes when I'm coming to a stop and I'm holding the clutch in to go down to first it wants to stay in neutral while I'm at a very slow roll or complete stop, after a few good pushes the neutral light goes off and I'm good to go. With that being said I get a little nervous with impatient cars behind me, perhaps I'm just not pushing it in hard enough or the bike needs broken in, any suggestions?
    Nov 2010
    Frostbite Falls Ill
    2,719
    Featherthe clutch as you press down. This will rotate the tranny parts so that an engagment slot in the gear cluster lines up and the dogs engage.
    Phelonius
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Colorado
    1,170
    Just stomp on the gear change lever some more, that's what I do. I've always thought the TW'S shifting was pretty weaksauce [probably cheap shift forks or drum or something?]. It doesn't have that positive feel when you shift like every other bike I've ridden. Sometimes I wonder 'did it shift? because i can't tell. well the rpm are lower so it must have shifted'. When I come to a stop, I always push down on the shifter a few extra times just in case I'm not in first. [I also spam the turn signal cancel button constantly and try to shift into sixth in the TW and seventh in the CBR nearly every time-you never know when one might have grown over night].
    TW-Brian and Yamahauln like this.
    Pleasanton, CA
    5,783
    This is pretty common behavior for my TW's. I try to down shift through the gears when coming to a stop so I don't have to try and do it while the bike is at a standstill. It may also help if you rock the bike back and forth slightly while pressing the gearshift down into first. It is also a good idea to keep the bike in gear while you are at a stoplight so you can make a quick getaway if needed.
    Frosty Hollow
    13,174
    Your experiencing something normal for the TW, but...
    TWilight mentions what you should look for, especially if something is wrong.
    TW-Brian mentions what very nearly all of us experience on the TW.
    Also, if you're gonna park your TW and are trying to get it into neutral before shutting it off and are having difficulty, hit the kill switch just above the starter switch. With the engine off you will most likely find it will now easily shift into neutral.
    Mel, TW-Brian, Fred and 2 others like this.
    Sep 2015
    Ohio
    58
    Thanks everyone, I'm going to look into all of this after I ride home tonight. I've never had many issues with my Yamaha stuff but felt I needed to make sure this was the nature of the beast. I'll check my clutch release return spring and oil tonight. I believe I have some Yamalube at the house if it needs replenishing.
    As funny as this sounds I'd take this little bike over an R1 lol, there's something special about being able to actually afford your dream bike, TDubin is the only way!
    Biking through Africa with Cornelis
    17,595
    ^^^this^^^
    admiral and Smitty Blackstone like this.
    1st John 1:9
    John 3:16
    John 3:17
    Junior Member davis4507's Avatar
    Aug 2015
    Seattle, WA
    15
    I have a new 2015 as well. I downshift to first when coming to a stop and sometimes 1st is a little harder to get into sometimes with a nice clunk.
    Smitty Blackstone likes this.
    Mar 2015
    Ynys Môn
    4,641
    Quote Originally Posted by TWilight View Post
    Someone on here has a picture of THAT.
    IF indeed the clutch arm return spring is OUT of place, it takes about 13 seconds, and costs ZERO money to remedy this....so NO worries.
    Your wish is my command oh Great One
    (just follow the clutch cable down to the engine, and make sure it looks like this - some of them come out of the factory without the spring sitting in that notch) ............
    - Hidden Content
    Hailey, ID
    3,407
    AND, when you get 1,500 to 2,000 miles on it, switch to full synthetic oil like Mobil 1 4T Racing 10w40. Both clutching and shifting action will benefit.
    grewen likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Long time lurker, first time poster
    By TW-Brian in forum General Discussion
    Last Post: 08-30-2014, 03:59 PM
  2. Long time lurker, time to finally buy.
    By jrpitdog in forum General Discussion
    Last Post: 10-04-2013, 10:39 PM
  3. First time I've checked mileage. Hard to believe?
    By moresnow in forum Technical Help
    Last Post: 07-12-2013, 09:41 AM
  4. Video time... (big-time stuck!)
    By bookm in forum General Discussion
    Last Post: 05-30-2012, 10:54 PM
  5. Fun Times!
    By Hutty in forum General Discussion
    Last Post: 07-22-2011, 09:19 AM
