TK carb - Setting float & clear tube test when off bike
Results 1 to 3 of 3
Like Tree3Likes
  • 3 Post By sjh953
Thread: TK carb - Setting float & clear tube test when off bike
    Junior Member sjh953's Avatar
    Apr 2015
    Modesto, CA
    28
    The older thread below has been a huge help for me in understanding how to set the float. (The thread seems to now be locked, or at least I couldn't find a way to add newer comments. Hence this new thread.)
    https://tw200forum.com/forum/technica...ing-float.html
    I was particularly interesting the idea of using the "clear tube" test to confirm (post #6) that the float is set correctly. After taking the carb on and off a few times I realized that the test could be done with the carb sitting on the workbench. This way, the float could be adjusted as many times as necessary -- and THEN, when correct, put back on the bike.
    Here are photos of the system I came up with.
    The set-up is an 8x11 shipping box that I cut a notch into, where the throttle bracket can be hung. In the photos, the box is sitting on top of a toaster oven; the white paper in back of the carb is there for contrast. At the back of the box is a weight to keep the whole thing from tipping forward.
    The small funnel is fitted to the intake, and the clear tube from the overflow outlet is kept in place with the push pins. A kitchen measuring cup is used to start the siphone and catch any excess, and for when I need to dump the fuel to make another float adjustment. Under the carb is cookie baking sheet, with raised edges, to keep runaway fuel off my workbench.
    I hadn't seen this approach mentioned, so I thought it may be useful to someone.
    admiral, TW-Brian and jbfla like this.
    Frosty Hollow
    13,174
    I wonder if, within similar spec's, this would work on any motorcycle carb. I'm working on getting son #3's Honda CM400 back up and running (for me to use). It has dual carbs so it's double the trouble and they are already off while I work on it. Thanks for posting this even if it won't work on the Honda carbs.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    Great idea and pictures. I will try this system when I replace my base gasket this winter.
    Thank you kindly, MAC
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
  1. Last Carb setting question (maybe)
    By YankeePrepper in forum Technical Help
    Last Post: 04-27-2015, 11:36 AM
  2. Base Line Carb needle setting, PICS of Carb? 1989 TW200
    Last Post: 04-24-2015, 06:04 AM
  3. Setting the float...?
    By DIS-KO in forum Technical Help
    Last Post: 08-24-2014, 04:48 PM
  4. Setting Float
    By wayno in forum Technical Write-Ups
    Last Post: 02-27-2014, 07:39 PM
  5. Adjusting the Carb Float
    By mattmus4357 in forum Technical Help
    Last Post: 02-08-2013, 08:13 AM
tk carb
tk carburetor forum
