Speedo drive / Front wheel
Results 1 to 6 of 6
Like Tree8Likes
  • 1 Post By immgunn
  • 2 Post By scotti158
  • 2 Post By wrench-puller
  • 1 Post By immgunn
  • 1 Post By immgunn
  • 1 Post By jtomelliott49
Thread: Speedo drive / Front wheel
    Senior Member immgunn's Avatar
    Sacramento, CA
    172
    Question: Are there supposed to be tabs on the left side of the front wheel to drive the speedo drive? My speedometer quit working. I suspected the speedo drive on the left side of the front wheel. Upon inspection, I saw a piece of metal jammed between the drive & pinion gears. A new drive assembly is about $60. Before I spend $60 on a new drive assembly, what spins the drive assembly's drive gear? I don't see anything. I suspect there's supposed to be tangs or tabs on the left side front wheel hub similar to those of the right side front wheel hub, but there's nothing. Anyone familiar with this? If so, please advise.
    Front wheel / right side
    Front wheel / left side
    jtomelliott49 likes this.
    May 2013
    Groton, NY
    2,663
    My 2013 has the tabs on both sides of the hub. The tabs are the "speedo driver". Not sure why they are on both sides though.
    immgunn and jtomelliott49 like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member wrench-puller's Avatar
    Ladysmith, B.C.
    548
    Quote Originally Posted by scotti158 View Post
    That's for british right hand drive ???
    It appears that the tabs that drive the speedo are worn off your wheel hub, see if the speedo gear still turns. If it is tight or seized that is probably what has damaged your wheel. Your local welding shop should be able to build up the tabs to match the other side or you will have to replace your front wheel. There is a used speedo gear on E-bay if you need to replace yours - Yamaha TW 200 TW200 Trailway 2001 2015 Front Speedo Gear 5EK 25190 00 00 | eBay
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    Sacramento, CA
    172
    Thanks.
    Sacramento, CA
    172
    Thanks. The speedo drive is froze. Actually, there's a piece of metal jammed in between the pinion & drive gear. I'll either have to have the wheel repaired, buy a wheel or look into an electronic speedo. I appreciate the info. Ride safe.
    Sep 2012
    Wichita, KS
    1,871
    I don't know anything about this, but have heard of gps speedo. Some of you techno guys will have to inform.
    immgunn likes this.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
  1. 60's 2 wheel Drive Trail Bike
    By mrutkaus in forum Off-Topic
    Last Post: 01-03-2016, 02:24 AM
  2. Two wheel drive motor cycle
    By arrowsmith in forum Off-Topic
    Last Post: 05-13-2014, 06:32 PM
  3. Two wheel drive motor cycle
    By arrowsmith in forum Other Bikes
  4. Who Said You Need 4 Wheel Drive
    By ronnydog in forum General Discussion
    Last Post: 11-09-2012, 08:55 PM
  5. All Wheel Drive Christini
    By SParks in forum Off-Topic
    Last Post: 03-09-2012, 12:36 PM
Tags for this Thread
