No electric 2008 tw200
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Like Tree23Likes
Thread: No electric 2008 tw200
    Junior Member cityot's Avatar
    May 2015
    15
    original owner. I was riding the bike at slow speed close to home. The bike quit. There is no sign of electric power going to anything, Nothiing to the instrument lights, headlight, starter, turn indicators, etc. The fuses look fine (is one a spare?). No previous trouble after 20,000 miles of laid back riding. What are the most likely things to check on a TW200 after fuses that look fine. Could a fuse look perfect and still be bad? Thanks in advance for any assistance.
    Skiing the slopes in Switzerland
    17,581
    Welcome to the forum!! Where are you from?
    I would check and clean the connections at the battery and the ground. Do you have a voltmeter? How many volts does it show for the battery?
    TWilight likes this.
    1st John 1:9
    John 3:16
    John 3:17
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Hello and welcome! Check your fuse(s) with a multi meter if you have one, if not, get some new ones and try them. And, as LT said above check your battery connections first.
    littletommy and TWilight like this.
    Frosty Hollow
    13,169
    Yes one of the fuses is a spare.
    May 2015
    15
    Thanks for the quick feed back I replaced the fuses even though the originals tested good. Battery has a charge (the motor started normally before the trouble). I disassembled the battery posts, wire brushed, touch of grease, reassmbled. I put a lead on the negative post and the other on the frame, bypassing the ground wire and the meter noticed that so doesn't that mean a signal from the post through the frame to the ground wire connection on the frame back to the negative post? Bike is still electrically dead. What next?
    I'm in Grosse Point Park Michigan. I generally ride the Tdub from there to historic fort wayne staying close to the Detroit river. Stopping places likeThree mile park, Angel Park, Belle Isle Park, Riiver Walk, Joe Louis, several boat ramps, fishing spots, etc. Then scattered along the way are graveled areas where I do balance practice, Mostly ultra slow ride in straight lines or circles. Or I ride the front wheel into a pot hole, stop, balance, climb out without putting a foot down, etc. May be I care more about the skills than just riding around. Up on the farm is a klx300r bought used. A bit large for the trail riding I do but you ride what you got. The Tdub is an excellent excellent bike for balance practice. I practice on gravel because it lubricates the front tire so less front tire wear sawing the forks side to side to keep the bike up. Balance and muscle memory manage lean and traction. Thanks again for the assistance.
    Apr 2014
    Dryden NY
    6,343
    Bad key switch?
    Tom
    rbm
    rbm is offline
    Jan 2011
    4,305
    Check every connection on the bike, pay close attention to the connectors behind the headlight.
    May 2015
    15
    I can do some disassembly and wiggle everything. What ever the problem it is a wire or device that can stop all power to everything. There would be a limited number of things that can do that. Does anyone know where I can find an electrical diagram? 2008 bike.
    Mar 2015
    Ynys Môn
    4,631
    - Hidden Content
    Sep 2012
    Wichita, KS
    1,871
    Maybe a dumb suggestion, but is the battery okay?
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
  1. 2008 tw200 (va)
    By kmroxo in forum TW200 Classifieds
    Last Post: 03-10-2014, 11:08 AM
  2. Replies: 7
    Last Post: 03-01-2014, 02:43 PM
  3. 2008 TW200
    By BNAllen in forum TW200 Classifieds
    Last Post: 02-04-2014, 05:37 AM
  4. tw200 2008
    By wentzel in forum General Discussion
    Last Post: 05-18-2012, 03:13 AM
  5. 2008 TW200 in Az
    By flemsmith in forum TW200 Classifieds
    Last Post: 07-24-2011, 04:12 PM
2008 yamaha tw200 no electrical power
tw200 no electricity
yamaha tw200 fuses amperage
