2007 california model carb problems
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By rbm
Thread: 2007 california model carb problems
    Senior Member Rider21's Avatar
    Aug 2015
    Reno, NV.
    432
    Picked up 2 TW's, a 2000 and a 2007 for the price of one. Selling the 2007 as the 2000 has a kickstarter. The 2007 has starting issues. Usually it will start right away with no choke but doesn't always want to stay running continually until it's warm. Using the choke it won't start a all is either position. I find this odd. Never have seen this problem before. I went through the carb and all looks ok. The only problem there might be is the fuel screw tiny oring is maybe slightly deformed. Warmed, the bike runs great, better than the 2000. Is there any benefit to replacing the carb with a 49 state carb?
    Thanks, Dwight
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    I'd bet you have a bit of crap in the carb. I would start with a double dose of Seafoam and some fresh fuel, run it for a while to ensure the Seafoam gets into the carb then let it sit overnight. Repeat several times and see what happens. This worked wonders for mine when I bought it, very similar symptoms as yours.
    jbfla likes this.
  1. Oh no! I bought a California model...
    By Ricklesss in forum Technical Help
    Last Post: 02-28-2015, 08:05 AM
  2. 2007 TW200 problems starting
    By NEO-snow in forum Technical Help
    Last Post: 08-09-2013, 04:50 AM
  3. Register Non CA Model in California?
    By eddy in forum General Discussion
    Last Post: 11-06-2011, 09:35 PM
  4. Replies: 6
    Last Post: 10-17-2011, 01:24 PM
  5. 2007 TW200 For Sale in California
    By daisydela in forum TW200 Classifieds
    Last Post: 09-07-2011, 11:45 PM
