Rough idle 95 model
Results 1 to 5 of 5
    Junior Member richconn's Avatar
    Apr 2011
    8
    I've got a 1995 model with a rough idle. Ive cleaned everything that can be cleaned. It will idle for a little bit, slow down, not idle smooth then eventually die. Any suggestions?
    Quote Originally Posted by richconn View Post
    Does it run well at at sustained higher rpm under load?
    Apr 2011
    8
    YES
    Apr 2011
    8
    I downloaded a service manual and noticed that my pilot adjustment screw is sealed. Can that plug be removed to alow adjustment of the pilot?
    Yes. That is a highly recommended adjustment.
    I expect there is some crud in the fuel passages in the carb. Seafoam and patience may work that out.
    Might want to do the starting fluid vacuum leak test. The rubber parts of the crab and intake crack and leak.
  1. Runs rough when damp and cold
    By atleastbehandy in forum Technical Help
    Last Post: 06-18-2013, 11:55 PM
  2. Rough, Jerky Clutch
    By retmotor in forum Technical Help
    Last Post: 08-16-2012, 05:26 PM
  3. Trying to smooth out the rough spots
    By mhomadness in forum Technical Help
    Last Post: 07-01-2012, 08:21 PM
  4. Battery died on a rough ride
    By tfactor in forum Technical Help
    Last Post: 05-09-2012, 04:39 PM
  5. 89 TW200 runs rough and sporadically
    By smw08003 in forum Technical Help
    Last Post: 11-25-2011, 11:10 AM
