rocker shaft screw size....
Results 1 to 10 of 16
    Junior Member qkenuf4u's Avatar
    Apr 2011
    16
    ok i found a link to a thread from back in 09 but cant look at the pics etc...
    so i need the info on what size the thread are in the rocker arm shafts so i can fix my customers TW200...... (tip of valve is GONE)
    thanks
    lance
    918
    If no one chimes in with the answer, is the other valve adjustment screw in good condition? If so, remove it and find a thread size gauge.
    Sold bike.
    Apr 2011
    16
    Quote Originally Posted by pgilles View Post
    not looking for the screw/locknut thread pitch.. need the ROCKER ARM SHAFT thread pitch/tool.. theres a puller YAMAHA sells but dont know the pitch (6 x ??) i seen one other place it was 6 x 1.5 REVERSE THREAD but dont know for sure..
    thanks
    lance
    918
    Oh that part When I did my cam upgrade it said to remove those shafts in order to install the cam. Well, I didn't have to but I thought a bolt from the cam bearing retainer fit in it? I sort of remember trying to remove them but then figured out I didn't have to to install the cam. It's worth a shot until someone else who knows chimes in. I've searched XT's, YTM's and TW's on the web and came up with nothing on the thread pitch.
    When you find out, post it up!
    Sold bike.
    Apr 2011
    16
    thanks.... like i said i found a post from in 09 but couldnt look at pics or PM the people that started the thread... not sure what was up with that...
    thanks
    lance
    918
    Yeah, the old pictures don't carry over. When we lost that site, we lost the pictures...unfortunately. The manual doesn't state the thread size, but it says the p/n of the puller is YU-01083....googling that I found this site: http://www.thevirago.co.uk/viragoVir...nual--0108.asp
    The top right picture shows the puller and claims it's 8mm, but doesn't state pitch. So it should be either M8x1.25 or M8x1.0. But I can't say with certainty.
    Sold bike.
    Apr 2011
    16
    well crap.. i know for a fact they are 6mm after messing with them today at ACE hardware but like i said ive read they are REVERSE THREAD.... ill have to hit up the local yamaha shop and see if they can pull it for me... guess ill have to charge the customer whatever they charge me....
    thanks
    lance
    918
    Strange. Maybe Yamaha has different dash numbers for that puller for different applications? Can you confirm it's reverse thread by putting a light on the threads and taking a peek? Or it is too hard to see in there? Been a while since I dug in that far.
    Otherwise, there is a forum member on here by the handle "macbig2k1"...he could help you out. He's in Germany and owns a shop and would know this information... http://www.tw-parts.com/
    Sold bike.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Quote Originally Posted by qkenuf4u View Post
    thanks
    lance
    If this information can help you ...
    I made ​​my tool
    To extract the camshaft is the M10
    For the rocker shaft is the M6
    Sorry, but my English is bad ...
    Apr 2011
    16
    thanks CHRISTDDEL... but a normal 6x1.0 bolt wont thread into the rocker shafts so i do believe they are REVERSE THREAD.. ill look really close tomorrow after work and verify that.. they are also a pretty fine thread.....ive read they are 6 x 1.5...
    Quote Originally Posted by christddel View Post
    I made ​​my tool
  1. Idle gear shaft -- Need help!
    By epix in forum Technical Help
    Last Post: 03-08-2013, 01:40 PM
  2. Stripped shaft! How do I fix it?
    By PalmStateCrawler in forum General Discussion
    Last Post: 04-25-2012, 12:31 AM
  3. Rocker arm shaft interfering with head bolt
    By operose in forum Technical Help
    Last Post: 03-31-2012, 07:53 PM
  4. Counter-shaft Sprocket Coverectomy
    By Mad Mac in forum Performance and Customization
    Last Post: 02-06-2012, 10:23 AM
  5. cam chain sprocket on the crank shaft
    By christddel in forum Performance and Customization
    Last Post: 02-02-2011, 12:05 PM
how do you remove the cam bearing from a ytm 200
rocker arm yamaha mio thread
tw 200 how to remove rocker arm
virago rocker arm thread
yamaha rocker shaft removal
yamaha rocker shaft thread size
yamaha tool yu-01083
yamaha tw200 rocker shaft removal
yamaha yu 01083
yamaha yu-01083
ytm200 rocker arm removal
yu-01083
