What the heck???? needle question
Results 1 to 7 of 7
    Member chines75's Avatar
    Apr 2011
    Stationed in Seoul Korea
    68
    So I am in middle of rebuilding my carb. I got a few new items and put them in. I was having problems and pull it apart and found this little gasket. Do I need it? I never seen a picture of it in any other post.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Quote Originally Posted by chines75 View Post
    What year is your TW?
    If this is normal after 2002 see the photo
    Devon, England.
    614
    I have that rubber washer on my '04 bike.
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    my 09 had a screw, spring, washer, and o-ring only from factory. i also ordered a spare because i had one fall out once. my spare, which is the pilot screw kit from yamaha only has the screw, spring, washer, and o-ring. i just had mine all apart a few days ago.
    Oct 2010
    Belgium
    376
    Look at this post...
    https://tw200forum.com/index.php?/top...carb-cleaning/
    Apr 2011
    68
    Its a 2005. Thanks for the help but if you look at the pic you can see the o-ring next to the washer. I think maybe when the cut the o-ring this is left "like a super tiny o-ring?" over that I didnt see when i pushed it on and it popped out? So should I take the big one or little one off?
    Oct 2010
    Belgium
    376
    [/URL]
  1. What the heck is this?
    By rm_hm in forum General Discussion
    Last Post: 08-17-2014, 02:37 PM
  2. Carb float needle valve seat question?
    By Twowheeler in forum Technical Help
    Last Post: 01-08-2013, 12:34 PM
  3. float needle help
    By Malkop in forum Technical Help
    Last Post: 01-16-2012, 07:40 AM
  4. Replies: 3
    Last Post: 10-18-2011, 11:59 PM
  5. Carb Needle Shim Question
    By sfsccoter in forum Technical Help
    Last Post: 09-16-2011, 12:05 PM
