Differences in Ignition/Electrical
Results 1 to 9 of 9
    Junior Member Officebob's Avatar
    Apr 2011
    24
    Hi
    Can anybody explain the ignition system upgrades from 1987 to present?
    It was stated that there are three (3) generations if you will.
    Cheers & thanks
    Desert, SoCal
    7,369
    First Gen, if you will was 1987 only, first year of the TW. It had a separate lighting coil, the lights only came on if the bike was running. It had no front running light feature and the safeties were wired slightly differently from subsequent runs. It used a 1987-specific CDI unit. The left engine sidecover only accomodates the 1987 charging/lighhting system.
    Second Gen was '88-'01. It had an improved single phase, self-contained charging system, CDI was specific to those years, 35 watt headlamp, had front running lights and essentially the same system for the entire run. Left side engine cover again only accomodates components from these years
    Third Gen '01 to present. They have a higher output three phase charging system, higher wattage headlamp, their own corresponding CDI unit and self'cancelling turn signals. Nuther slightly different left side cover.
    Apr 2011
    24
    Lizrdbrth
    1000 Thank yous
    Bob
    Pleasanton, CA
    5,691
    Good summary lizrdbrth.
    One minor clarification. The Third Gen '01 to present do not have self cancelling turn signals (just wanted to save someone from trying to fix a feature that isn't there).
    Brian
    Desert, SoCal
    7,369
    Brian
    Sorry. I meant push-to-cancel. At least mine do.
    Apr 2011
    24
    My Yammie RD400s from the 70's had self canceling blinkers.
    If you forgot, the blinker would cancel at a certain distance
    of straight travel down the road.
    Cheers
    Senior Member Camelrider's Avatar
    Aug 2010
    Israel
    166
    According to the parts lists of 1998 till 2000, there is a different CDI unit and coil.
    They also cost less then the 88-97 parts.
    It looks like it that I need a new CDI unit for my 96 TW. I wonder if the cheaper 98 CDI will fit on the earlier models.
    Again according to the parts lists they all have the same generator till 2000, so it should be possible.
    Senior Member andy10889's Avatar
    Jan 2014
    Mobile, Al
    145
    I know this is old but the difference between the 97 and down and 98 and up is only the connector at the cdi box. I have a 93 cdi on my 2000 model and it works just fine, I did have to change the connector though.
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    567
    Nice grave dig....This is good important info that would save many of hours digging through manuals and parts lists
  1. Carb differences
    By macbig2k1 in forum Technical Help
    Last Post: 01-08-2013, 01:00 PM
  2. Differences between '98 and '09
    By kenfyoozed in forum General Discussion
    Last Post: 09-25-2012, 08:10 PM
  3. TW200 Differences between years
    By nfpgasmask in forum General Discussion
    Last Post: 08-14-2012, 03:37 PM
  4. carb differences?
    Last Post: 06-12-2011, 04:04 PM
  5. 1987 TW200 Ignition/Electrical Problem?
    By snowrider in forum Technical Help
    Last Post: 05-31-2011, 05:58 AM
1987 tw200 electric conversion
lizrdbrth
