Gas Leaking from Carb
Results 1 to 2 of 2
    Junior Member lrotunda's Avatar
    Sep 2010
    9
    I seem to have a gas leak from somewhere on the carburetor. I've changed the fuel hose from the tank but that didn't fix it. The leak also seems to be above the float bowl gasket.
    Any ideas?
    Desert, SoCal
    7,369
    Check the ends of the float bowl screws. When the float bowl gaskets start to lose their seal gas sometimes travels up the screws.
  1. bowl leaking
    By Jassenk in forum Technical Help
    Last Post: 05-08-2013, 09:04 PM
  2. Tappet cover leaking
    By Guitarman in forum Technical Help
    Last Post: 07-25-2012, 09:16 PM
  3. leaking smurf
    By mattzuki in forum Technical Help
    Last Post: 06-19-2012, 08:37 PM
  4. Carb Leaking
    By scbydo in forum Technical Help
    Last Post: 07-22-2011, 03:17 PM
  5. Gas leaking into air box overfill
    By Adam-n-nevada in forum Technical Help
    Last Post: 08-21-2010, 09:47 PM
2012 tw200 carburetor dripping gas
tw 200 carburetor gas leak
tw 200 gas smell
tw200 carb leaking
tw200 leaking gas
