Should I replace the base gasket--2006
Results 1 to 4 of 4
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    342
    I shouldn't have to ask myself this question(because I had previously decided to proactively replace), but what is the likely hood of the base gasket on my 2006 leaking in the future? I currently have 131 miles. I can feel that the two halves of the lower case where the cylinder mates are uneven. I have the plastics, seat, tank, and exhuast off for other modifications, so I was going to replace the base gasket. I am over reacting, or is there a high likely hood of a future leak?
    Thanks,
    Dusty
    866
    If it's the original gasket, it is definitely going to leak. Grit your teeth and replace it.
    Senior Member kj7687's Avatar
    2,436
    Quote Originally Posted by dustyg View Post
    Thanks,
    Dusty
    Personally I wouldn't replace it if it is not currently leaking. It's not like one of those things that will screw you randomly on the trail out in the middle of nowhere some time. And it's not difficult to get the exhaust and fuel tank and stuff off the bike. So if (when) you notice it start to leak oil, then replace it. My two cents...
    KJ, just KJ, ok.
    Current rides:
    Quote Originally Posted by kj7687 View Post
    +1
  1. wrong base gasket?
    By BoatHands in forum Technical Help
    Last Post: 04-08-2013, 11:17 PM
  2. Base Gasket Leak
    By bogey72 in forum General Discussion
    Last Post: 08-26-2012, 11:54 PM
  3. Did my base gasket today
    By Guitarman in forum Technical Help
    Last Post: 06-18-2012, 01:47 PM
  4. 07 base gasket leak
    By small's in forum Technical Help
    Last Post: 03-25-2012, 10:41 AM
  5. New base gasket reviews
    By kennethshaw in forum General Discussion
    Last Post: 05-11-2011, 07:10 AM
