Cylinder Parts Diagram Inconsistency
Results 1 to 5 of 5
    866
    Has anyone ever noticed that the parts diagram for the TW200 cylinder and the TW200 manual differ in the placement of the dowel pins? The parts diagram shows the two dowel pins going in the rearmost holes, with the o-ring going around the dowel at the oil feed on the right hand side of the engine/bike. The manual shows the dowels going in the two leftmost holes. Does anyone know which is correct?
    This is the parts diagram.
    This is the manual.
    Devon, England.
    614
    The 'o' ring goes rear right as you are sat on the bike.
    866
    Quote Originally Posted by uktw125 View Post
    But do the dowel pins go both on the left as sitting on the bike?
    Devon, England.
    614
    Quote Originally Posted by Rodney View Post
    Yes, dowels on the left 'o' ring on the right.
    I have just double checked a cylinder on the shelf and the right rear on the cylinder does not have a counter bored hole for a dowel pin so you can't really do it wrong.
    866
    Thanks, uktw125. That's what I thought, but I've already reassembled, and I wanted to make double sure. It's nice that it's "Murphy proof".
  1. Looking for TW 200M/MC wiring diagram
    By brah1 in forum Technical Help
    Last Post: 01-13-2013, 04:28 PM
  2. Carb parts not on the diagram
    By jgaff in forum Technical Help
    Last Post: 09-26-2012, 06:19 PM
  3. cylinder head
    By ldw72120 in forum Technical Help
    Last Post: 11-03-2011, 08:09 AM
  4. cylinder head
    By christddel in forum Technical Help
    Last Post: 02-28-2011, 04:38 PM
  5. Cylinder and Piston
    By Desertwndrr in forum Performance and Customization
    Last Post: 01-06-2011, 02:46 PM
