Do I have a reserve?
Results 1 to 5 of 5
    Apr 2011
    Martinsville Indiana
    2,089
    I ran out of gas the other day so I stopped and put it on reserve and it still wouldn't start. I thought since the reserve is probably at the bottom of the petcock it might have had something blocking it. I took off the petcock and the on side is just about a 1-1.5" tube/screenfilter sticking up from the petcock. The whole thing was a screen. Is this normal or is mine missing something. I just don't see why they put a reserve on the petcock if the on is basically the same as the reserve but with just a tube/screen sticking up.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,393
    Here's the TW 200 petcock. Does yours look like this?
    Image from Broken Veteran's petcock thread.
    https://www.tw200forum.com/forums/85249/ShowPost.aspx
    jb
    Apr 2011
    2,089
    Huh huh! Now I know why i was out of gas! I'm a missing the big one "ON"
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by Small's View Post
    Unless someone else took the petcock off, the tube should be rattling around in the tank somewhere.
    Stephen S.
    '07 TW200:
    Apr 2011
    2,089
    I'm gonna check. The guy who had it before me was mechanically challenged and I think he had a local shop tune it up and put on an inline fuel filter. A few shops around here have a bad rep and I've seen first hand how bad a few have been. Anyways thanks for the pics. Now I just have to find the tube or get another one.
  1. Mileage & Reserve Capacity
    By Mozart 2 in forum General Discussion
    Last Post: 06-10-2013, 09:08 AM
  2. Replies: 32
    Last Post: 10-25-2012, 08:39 PM
  3. miles to reserve xt350 oem steel tank
    By peruano in forum General Discussion
    Last Post: 07-23-2012, 03:47 PM
  4. when does your reserve kick in
    By YTWTX in forum General Discussion
    Last Post: 09-09-2011, 04:44 PM
