Kill Switch, Kickstand Switch, Clutch Switch
Results 1 to 6 of 6
    Junior Member twmonae's Avatar
    Aug 2010
    4
    Rode this weekend and noticed that my kill switch was not working . Thought I would check to see if the kickstand overide worked and it did not. Then checked the clucth overide and the bike started without the clutch engaged. Any clues?
    Senior Member Gene Bond's Avatar
    2005 TW200, Indianapolis, IN
    139
    Sounds like the ignition cut-off relay may be welded? Or has a previous owner bypassed the ignition cut-off switches? (I've done it on my lawn mower )
    TW200, Bruin, Sportsman, Ranger, Wrangler
    ----> Old Age Ain't for Sissies!
    Cheapest thing to check is that all the wires are hooked up.
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    Ahhh!! I have this problem periodically as well. Mine is caused by my right-hand lever/hand guard that I have clamped onto the right side handlebar. When it wiggles up it must pinch the cluster of wires and causes the safety/kill switches not to work...when I push it back down they immediately work. Check this area out, I say.
    Adam
    jvt
    jvt is offline
    Senior Member jvt's Avatar
    Enumclaw,washington
    136
    A poor ground will cause lots of problems.
    Member dawgs's Avatar
    Aug 2010
    64
    I wish all that crap on mine didn't work. It is all a pain in the butt. Things that one day will go bad and leave you stranded or working on it out in the middle of no where.
    I need to get busy and bypass all that stuff.
  1. ignition switch
    By easternfrontnh in forum General Discussion
    Last Post: 03-19-2013, 02:13 AM
  2. clutch switch malfuntion
    By prabath8989 in forum Technical Help
    Last Post: 09-07-2012, 07:39 PM
  3. About clutch switch
    Last Post: 09-02-2012, 10:07 AM
  4. Clutch Perch and safety switch
    By surfmansd in forum Technical Help
    Last Post: 05-24-2012, 08:26 PM
  5. Kill Switch Relay
    By twmonae in forum TW200 Classifieds
    Last Post: 09-02-2010, 08:46 PM
bypass kickstand kill switch tw200
dr200 kickstand killswitch
testing clutch safety switch tw200
tw200 clutch safety switch bypass
tw200 how to bypass clutch kill switch
tw200 kick stand kill switch removal
