H4 bulb question / What headlight setup do you have
Results 1 to 7 of 7
    Member chines75's Avatar
    Apr 2011
    Stationed in Seoul Korea
    68
    When I first installed the dual headlight kit to my bike I ran them both using H4 bulbs. Then I had the dumb idea to get brighter bulbs "H4 55/60w" that will drain the battery in about 3 miles. So now I can only run one and the other is for looks. Does anyone know if they make a smaller H4 bulb? I have searched the web with no luck.
    Please share you headlight setup also I am thinking of going with the black dominator kit as I add some mods to the bike when it comes back later this week.
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    Chines, I was wondering about this very topic as well. I have a headlight to install that comes stock with both an H8 and an H11 bulb. Don't know if I can run those.
    I am not an electrician, but I DID just read a wikipedia article on headlamps which included this bit:
    "...[S]ingle-filament bulb designs include the H7 (55 W @ 12.0 V, 1500 lm ±10% @ 13.2 V), H8 (35 W @ 12.0 V, 800 lm ±15% @ 13.2 V), H9 (65 W @ 12.0 V, 2100 lm ±10% @ 13.2 V), and H11 (55 W @ 12.0 V, 1350 lm ±10% @ 13.2 V).
    The first dual-filament halogen bulb (to produce a low and a high beam with only one bulb), the H4, was released in 1971. The U.S. prohibited halogen headlamps until 1978, when halogen sealed beams were released. To this day, the H4 is still not legal for automotive use in the United States. Instead, the Americans created their own very similar standard (HB2/9003). The primary differences are that the HB2 sets more strict requirements on filament positioning, and that the HB2 are required to meet the lower maximum output standards set forth by the United States government.
    The first U.S. halogen headlamp bulb, introduced in 1983, was the 9004/HB1. It is a 12.8-volt, transverse dual-filament design that produces 700 lumens on low beam and 1200 lumens on high beam. The 9004 is rated for 65 watts (high beam) and 45 watts (low beam) at 12.8 volts. Other U.S. approved halogen bulbs include the 9005/HB3 (65 W, 12.8 V), 9006/HB4 (55 W, 12.8 V), and 9007/HB5 (65/55 watts, 12.8 V)."
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    Senior Member rm_hm's Avatar
    1,619
    Hmm maybe a pair of these ?
    [media]http://www.youtube.com/watch?v=tTgkEcUKfC8&feature=related[/media]
    1996 TW200 Edmonton, AB
    590
    Candlepower sells a 45/45 H4 bulb:
    http://store.candlepower.com/mobu.html
    Two is still 90 watts though.
    I think I have a 35 watt in mine, but not sure if that is H4.
    Apr 2011
    68
    I have seen the LED but to pass the inspection I have to have high/low beam. I dont think I have read any where that they do. I did find some H4 35watt bulbs on google.com shopping so I guess that the route to take.
    1,619
    High & low ones are out there.
    Example
    http://www.youtube.com/watch?v=g5VgJfsfhVY
    Senior Member Gene Bond's Avatar
    2005 TW200, Indianapolis, IN
    139
    One would think with 3 terminals it would be high/low beam setup, but who knows...?
    A quick E-Bay search shows a bunch of 'bargains', but sometimes you get what you pay for
    http://shop.ebay.com/i.html?_nkw=led+headlight+bulbs
    Personally, I don't ride much after dark... the bugs leave a bad taste in my mouth!
    TW200, Bruin, Sportsman, Ranger, Wrangler
    ----> Old Age Ain't for Sissies!
  1. Dual Headlight Setup.....Got em'?
    By Gary in Pennsylvania in forum Performance and Customization
    Last Post: 03-12-2014, 01:50 PM
  2. 1990 headlight question
    By Bizz in forum Technical Help
    Last Post: 06-19-2013, 11:55 PM
  3. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 11:52 PM
  4. Quest for a brighter headlight with stock fixture / DOT bulb
    By praeses in forum Performance and Customization
    Last Post: 08-12-2011, 11:14 AM
  5. Headlight bulb question
    By darnold87 in forum Technical Help
    Last Post: 03-25-2011, 08:22 PM
2013 tw200 bulbs
led headlight
seoul h4 55 watt
tw200 headlight 35 w & 55 w
will a 45 watt h4 bulb be bright
