Are these good tire irons?
Results 1 to 10 of 14
    Senior Member Mark In WA's Avatar
    Southwest Washington State
    165
    With 7K miles on the TW it's time for a new front tire. I think I am going to try the Bridgestone TW302. I probably ride more than 99% on the street, but I don't want strictly street tires. To me this tire is kind of similar to the stock TW34 rear with larger knobs that are somewhat staggered. I'm hoping it won't howl as much as the TW31. Also as best as I can tell this tire is not heavy like the Kenda K270 or IRC GP-1. Has anyone here tried this tire on the front?
    Bridgestone TW302 Trail Wing Dual Sport Rear Tire
    I've never changed a motorcycle tire myself but since I'm doing all the maintenance I want to try it. Searching the forum people have made some general comments about tire irons, mostly that they like the old ones they've used for years. I am wondering if you experienced folks could give me specific recommendations on the different types I see on the Motorcycle Superstore website.
    Is this a good way to get started?
    Motion Pro Assorted Tire Iron Set
    In the reviews, people complain that these tend to damage the wheels and mine are the black ones. They also say the smallest one is not very useful, but I am thinking about modifying it to hook onto a spoke like qwerty described.
    Or would these be better?
    Motion Pro Spoon Tire Iron
    The reviewers mention these are less likely to damage the wheels or pinch the tubes. 3 of them would cost more than the above set, and they would all be the same size.
    So what do you guys think? Are there other options I should be looking at? I hope you guys don't think these are dumb questions because I have zero experience with this.
    Mark
    '10 Truimph Bonneville Std.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    If you are not going to carry them with you, I prefer the longer, heavier tire irons.
    Seems like I have collected a few over the years.
    I use three and prefer the spoon ends.
    On my bikes that have fancy cast wheels, I use rim protectors under the tire irons.
    jb
    Ephrata, WA
    1,125
    Mark
    [/quote]
    I have these and I love them. It takes some muscle to put on the back tire, but its doable. The rounded (spoon) end is awesome and even though I've pinched my tube, I have yet to cut one. I bought three and they have paid for themselves already.
    1990 TW200
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    i used two cheap red handled tire irons a few weeks ago to swap out my stock tires with the 203/204's.
    they are like these:
    it was a piece of cake. i had both tires off and the new ones on in about an hour to an hour and a half. the front one was really easy.
    Senior Member Beewerks's Avatar
    Apr 2011
    Longmont, Colorado
    118
    Not to thread jack, but do you have to get the wheels balanced once you get the new tires installed?
    '05 TW200--15/50 gearing, Cyclerack, XT350 tank
    '81 KZ750--project bike
    Senior Member shocker's Avatar
    Orange Park, Florida
    164
    JC whitney has some tire tools. Low price. I got a bead breaker from them also. Front tire balancing is important. I mounted my Fat Shinko 428's front and back then I had the front balanced after riding it about 100 miles-was needed. Usually new tires have a yellow mark on the side wall to indicate location of valve stem when mounted it should line up to. Never hurts to ride it first to see if you need a balance.
    FL. GA, NC
    2,392
    Quote Originally Posted by Beewerks View Post
    Yes, since I have a tire balancer. Some people don't and have no problems.
    IMO, if you are going to travel at highway speeds, and not slow trail riding, it's a good idea to balance the tires.
    I use one like this:
    http://www.rockymountainatvmc.com/pr...FamilyId=26856
    A similar one from Harbor Freight at a lower price:
    http://www.harborfreight.com/motorcy...and-98488.html
    jb
    Senior Member rm_hm's Avatar
    1,619
    I'm a fan of these.....
    http://www.stubbytiretools.com/
    They will not scratch rims
    Senior Member pantera1's Avatar
    Oct 2010
    Minnesota
    176
    Good luck with the TW302 in front.
    Please report back with your results. I too have thought about using this as a front tire.
    2007 FZ1
    1991 TW200
    1972 CB350
    2006 Goldwing
    2008 WR250R
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    I'll say, "tried and true" Gerry
    Take care my Friend.........
  1. GOOD OR NOT?
    By SMALLBLOCK116 in forum General Discussion
    Last Post: 03-09-2013, 07:19 PM
  2. Good MPG
    By stephenmarklay in forum General Discussion
    Last Post: 03-02-2013, 12:26 AM
  3. Richochet Skid plate, X-RING chain, handguards, tire irons
    By Shellmoney in forum TW200 Classifieds
    Last Post: 02-27-2013, 05:02 PM
  4. Good Bike
    By gskeem in forum TW200 Classifieds
    Last Post: 12-28-2012, 06:00 AM
  5. Hello...and good day!
    By ZXtasy in forum General Discussion
    Last Post: 12-18-2010, 10:51 AM
j c whitney tire spoons
tire iron
tire iron spoon pm
yamaha tw200 tire iron
