'91 TW200 ?'s
Results 1 to 3 of 3
Thread: '91 TW200 ?'s
    Junior Member cthunter's Avatar
    May 2011
    26
    Just bought a '91 Tw 200 today. Not familiar with them and was wondering if there is anything I should expect or watch out for on a '91.
    866
    Quote Originally Posted by cthunter View Post
    The 91 model is a very solid machine. No specific problems that I'm aware of. Just do a tune up and a service. Change the oil, clean or replace the air filter, change the spark plug, check the valve adjustment. If in doubt, take the bowl off of the carburetor and check it out. Lube the cables and levers. Check the brakes, check the chain and sprockets, replace the tires if needed.
    There is one thing that all TW's seem to suffer from. Make sure the clutch is adjusted properly and that it's return spring is in place.
    May 2011
    26
    Quote Originally Posted by Rodney View Post
    Great, thanks much for the info.
tw200 91 model problems
