more carb questions
Results 1 to 3 of 3
    540
    OK I am fighting a fuel problem with 87 TW200. The guy before me said it was rebuilt, and Im not to sure it was done correctly. Run good, then bad, then good, then bad. Like fuel starvation.
    As I look at the 87 service manual I see that there are a few orings. Number (11). The drawing shows a oring above the collar of number (12). Mine did NOT have this on, only the one near the bottom close to the threads on number (12)
    Same thing on the float valve. there is a oring pictured (11) above the valve body, mine DID NOT have this one, only the one that on the body itself, below the the little screen cap.
    Please give me some guidance, thanks
    Senior Member Snake2715's Avatar
    Aug 2010
    166
    I am newer to carbs as well. however I am fairly certain that the 1987-2000 carb were the same..
    Check my thread here where I have a few pics. The orings should be in he right spot here. I dont have the original link to some of these pictures.
    https://tw200forum.com/index.php?/top...uni-carb-help/
    Good luck.
    540
    Great info and pics
    thank you very much
  1. Lazy Man's Carb Cleaning Questions
    By Avi Kwame in forum Technical Help
    Last Post: 04-09-2013, 07:06 PM
  2. A few questions
    By nfpgasmask in forum General Discussion
    Last Post: 12-10-2012, 01:30 PM
  3. Carb questions
    By RisingSun in forum Technical Help
    Last Post: 09-01-2011, 11:33 PM
  4. last round of carb questions
    By phazer in forum Technical Help
    Last Post: 08-06-2011, 05:44 AM
  5. Newer CV carb vs. older carb. MPG
    By number356 in forum Technical Help
    Last Post: 03-28-2011, 11:25 AM
