Carb Rebuild Kit
Results 1 to 10 of 11
    Junior Member DetroitRed's Avatar
    May 2011
    8
    My 1987 TW200 has developed a carb leak. I believe that it's the float needle and/or the seat o-rings. Does anyone have any ideas where I can get a rebuild kit with those items and the other O-rings for this Teikei kikaki carb?
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    There is a rebuild kit offered on Ebay. However, those who have purchased it have not been very pleased with the contents.
    It's best to buy the individual pieces from an online OEM parts vendor.
    Recently I have been very pleased with the prices and reasonable shipping of Ron Ayers.
    http://www.ronayers.com/
    But there are others.
    jb
    May 2011
    8
    Quote Originally Posted by jbfla View Post
    jb
    May 2011
    8
    thanks JB. I will look into that.
    Senior Member kelly b's Avatar
    Mar 2011
    Indianapolis, IN
    162
    I bought the ebay kit. I just restored a 93, put all the desirable farkles on, and was most satisfied w/that rebuild kit. Loved the oversized jet that created the super smooth idle and took away most of the cold running issues I had prior. Best $35 I spent on the whols restore!
    FL. GA, NC
    2,399
    Kelly, thanks for the update on the Ebay rebuild kit,
    It's good to hear a favorable review.
    jb
    6,985
    Quote Originally Posted by kelly View Post
    It sure must have been a different kit than the one I got off ebay. The one I got was dog do-do. The only part I am still using is the float bowl gasket. The float needle worked for a month or two and then started leaking. The high speed jet looked good but I didn't need it. All the other parts were just plane wrong. Hopefully the kit has been updated / corrected so all the parts now work.
    Junior Member jpalombo's Avatar
    Aug 2012
    3
    I have the same issue, plus flooding while riding. How about this kit?
    http://www.motorcyclecarbs.com/CARBU..._P8904C697.cfm
    Senior Member FnMag's Avatar
    493
    Check your petcock before going for the rebuild. It will only take a few minutes...
    Take fuel line off with petcock in off position. If you get the slightest dribble, it's the petcock. Mine was dripping once a second or so and it was enough to fill the bowl and make it leak.
    Aug 2012
    3
    Well, it doesn't leak when the fuel is off, but shouldn't it also not leak when the fuel is on?
  1. New Carb Rebuild Kit
    By Mongo357 in forum Technical Help
    Last Post: 01-24-2015, 11:18 AM
  2. Top End Rebuild Kit
    By Bobvreal in forum Technical Help
    Last Post: 10-07-2013, 07:36 AM
  3. rebuild of a TW
    By Havoc in forum Performance and Customization
    Last Post: 05-30-2012, 09:37 AM
  4. carb rebuild kit for a 2007
    By mhussnatter in forum Technical Help
    Last Post: 03-18-2012, 09:41 AM
  5. Head rebuild
    By whitewash in forum Technical Help
    Last Post: 08-04-2010, 07:58 PM
1987 tw200 carb rebuild
1990 tw200 carb rebuild kit
1995 tw200 carburetor rebuild kit
carberator kit for yamaha 200tw
tw200 carb kit
tw200 carb rebuild
yamaha tw200 carb rebuild
yamaha tw200 carburetor for sale
yamaha tw200 carburetor kit
yamaha tw200 carburetor rebuild kit
yamaha tw200 carburetor schematic
