Installing O-Ring Chain
Results 1 to 7 of 7
    Member Justin5117's Avatar
    Sep 2010
    44
    I have a 2008 TW 200, I'm 21, I learned how to change my oil all the basics but never learned how to change chains. I bought a o-ring chain. How do I get the old one off? What do I have to do to put the new one on? Is there any instructions anywhere? Sry for the newbie question but being young i don't have the wisdom of you guys who been at it for years.
    2008 Yamaha TW 200
    Lowered Two-Inches
    Vapor Digital Speedometer/Tach
    Senior Member Fishman393's Avatar
    Apr 2011
    Cincinnati, Ohio
    116
    Justin5117
    It has been my experience with this forum that all you have to do is search this site and someone on here has been there done that with their TW. Try this thread https://tw200forum.com/index.php?/top...ter-link-clip/. If that does not work search around I bet you come up with an answer.
    Apr 2011
    Cincinnati, Ohio
    116
    Here is another one for when you get your chain installed.....https://tw200forum.com/index.php?/top...k-measurement/.....
    1996 TW200 Edmonton, AB
    590
    Those links pretty much have it. The only other things I can think of is the clips come off easiest with a good pair of regular square nose pliers end-on, ie one jaw on the pointy parts of the clip and another on a pin. Press the jaws together and 'hey presto' the clip comes off. That and feed the new chain on with the old one, ie, before you pull the old chain off, connect it temporarily to the new one with the master and use it to pull the new one around the front sprocket.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    If you don't have a masterlink press I've found that a small pair of vicegrips works well. Also paint the side plate of your master link a bright color like yellow to make it ez to find. It will also act as a start/stop point for chain lubing.
    Senior Member joedirt1970's Avatar
    Cardiff by the Sea, CA
    1,345
    Paint the side plate of your master link a bright color like yellow to make it ez to find. It will also act as a start/stop point for chain lubing.
    Good call. Sometimes the smallest tricks work the best.
    Hidden Content [/IMG]It's not why, but why not. Do it for the right reason now, versus the wrong reason later.
    Born on a Honda Z50, '78 YZ 80, '79 Husky WR 250
    2008 TDub--Jimbo Shield, Lizard Oil Cooler, Blaster Shock, YZ Hybrid Forks, Supermoto front fender, ATV Bars, Acerbis Brake Cover, 1460 Pelican Case, Cycle Rack, Power Core, Gold Chain.
    Lake Placid,Florida
    3,786
    Quote Originally Posted by Brock View Post
    Small tricks and Loc-tite have saved the day for me many times!
  1. Installing oring chain master link clip
    By mrutkaus in forum Technical Help
    Last Post: 02-07-2019, 11:35 AM
  2. New o-ring chain is on
    By goldenhtr in forum Technical Help
    Last Post: 07-31-2012, 07:35 AM
  3. what do you use on your O ring chain
    By aladdin in forum General Discussion
    Last Post: 05-30-2012, 03:48 PM
  4. DID O Ring chain
    By cdsdave in forum Technical Help
    Last Post: 04-03-2012, 04:40 AM
  5. Standard vs. O ring vs. X Ring Chain
    By Fishman393 in forum General Discussion
    Last Post: 05-14-2011, 05:46 PM
