Frame is broken on my 89
Results 1 to 3 of 3
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    I pulled my gas tank and found that the brace from the front of the bike where it attaches to the motor mount has broken the top rail
    mostly off. I don't really want to change frames because the bike is titled to the stamp on that frame. Surely this can be welded by
    the right person and perhaps gussets added. Or does it get parted out and reincarnated into another?
    Greybeard
    866
    Quote Originally Posted by Greybeard View Post
    Greybeard
    A good welder can fix it with no problem. I like the gusset idea.
    Aug 2010
    264
    Quote Originally Posted by Rodney View Post
    Thanks for responding. I have been away for a couple of years.
    I think the design is weak, and it could have been improved if the material had been butted
    into the attachments of the members that go around the mono- shock. The first one (right side)
    is only about an inch away, and the left much shorter. But the tank has an 8cm gap in the
    bottom for the 4cm frame. Room to add plenty of what Yamaha missed. I also thought of putting
    a tensioning bolt inside by removing the shock but hadn't conceived of how to secure the nut
    in the tube other than bonding it. Ideas, anyone?
    I wonder how many of you have cracks under your tanks you don't know about. After the seat it is
    only one bolt to find out. And possibly it can be checked all assembled.
    DN
  1. Broken 91
    By arrowsmith in forum General Discussion
    Last Post: 05-15-2013, 02:52 PM
  2. I need a frame
    By LittleCowTW in forum TW200 Classifieds
    Last Post: 04-24-2013, 11:31 AM
  3. Broken Vet's doing ok.
    By Xracer in forum Off-Topic
    Last Post: 04-11-2013, 08:36 AM
  4. Broken Vets doing OK.
    Last Post: 08-03-2011, 08:11 AM
  5. Speedometer broken?
    By Henrici in forum Technical Help
    Last Post: 11-08-2010, 04:21 PM
tw200 frame broke
