Front sprocket issue
Results 1 to 6 of 6
    Junior Member SRTeric's Avatar
    May 2011
    26
    Hey all, just bought my first tw (08)and was going to do a few mods, including an o ring chain and 15 tooth front sprocket. I was going to order 80574415-15 (parts unlimited) through dennis kirk until i read the description and saw that it spec'd the sprocket at a 520 chain size, while the stock chain (which i already ordered an o ring replacement for) is a 428. I held off from ordering the sprocket for the moment (though it lists it as correct for the tw) because im not sure if its a misprint on dk or if thats just the wrong sprocket for my bike. Anyone ordered this sprocket and had ok luck, or is the 520 description true? Any suggestions are appreciated. Thanks!
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    I'm going to say it was a mis-print. The 2006 TW that I own does indeed use a 428 chain & sprocket. I have replaced both a number of times and always have been presented with the "428". Gerry
    Take care my Friend.........
    Ephrata, WA
    1,125
    Weird. I looked it up and it does say that the size is 520 and it fits the TW. I'd give them a call before you buy to confirm the size.
    1990 TW200
    May 2011
    26
    I called dk, and though the guy was less than helpful, he did look up the part number and confirm that the sprocket is indeed a 428, not the 520 as it is listed.
    May 2011
    26
    Rather than starting a new post, ill add on... Ive got the correct yamaha gasket for the case cover when i do the sprocket swap, but do you guys suggest anything else to put on it when i put the cover back on? Any rtv or other sealants suggested? Ill be careful when removing the old gasket from the case and cover, but id like to avoid any possible leaks if you guys have already been there, done that. Thanks!
    Devon, England.
    614
    Here's a tip for you. When you put the new gasket on, put it on dry on the engine side but put a little smear of grease on the side cover. If you need to remove it again the gasket will stick to the engine but not the side cover. It will be OK to use again if you need to take the cover off again.
  1. Front Sprocket
    Last Post: 09-30-2012, 07:46 PM
  2. Front Sprocket
    By old betsy in forum Technical Help
    Last Post: 09-01-2012, 04:07 AM
  3. Front sprocket
    Last Post: 07-20-2012, 06:54 AM
  4. front sprocket
    By JMFLH in forum Technical Help
    Last Post: 10-24-2011, 01:24 PM
  5. Front sprocket noise?
    By Little Valy in forum Technical Help
    Last Post: 10-14-2010, 10:05 PM
