pool of gas
Results 1 to 6 of 6
Thread: pool of gas
    Member bradbeer's Avatar
    Mar 2011
    Elkhart, IN
    44
    Hey guys. Does everyone turn off their gas when they are not using bike. Last 2 times I ran out of gas, used reserve, filled up, and parked it I have come back to a small pool of gas below bike. After a ride it stops because I always forget to shut off. My other bikes have never done this. Is it cause by using reserve? Filling up all the way full? Or is there a leak possibly or something else wrong.
    Thanks
    Just got TW200 4/2/11! First bike I have owned capable of hitting dirt/trails
    97' TL1000s and 94' FZR 600
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Quote Originally Posted by bbb View Post
    ...Does everyone turn off their gas when they are not using bike....
    It's a good idea.
    ...Or is there a leak possibly...
    Does it look like this?
    If it stops leaking soon after you fill up the tank, you may have just overfilled the tank.
    Not a big problem.
    This is not very clear as to what you mean.
    If it continues to leak after you have parked the bike, you have a carburetor leak.
    If it's a large puddle (like a flood) of gas, it is likely the float valve stuck open.
    If it's a smaller leak, as in the photo, it's the o-ring on the float valve seat that needs to be replaced.
    Either one involves taking the carb apart.
    jb
    Mar 2011
    Elkhart, IN
    44
    It is very very small puddle like the picture. I tested it and if I shut the gas off it doesn't happen And if I leave the gas open it makes that's very very small puddle.
    GuessI need to out where carb is and that o ring thingy.
    Lots of useful info here and I think somewhere I saw a full manual download. This site rocks.
    Your help and comments JB were very helpful. Thanks for taking the time.
    Maybe if I just keep shutting gas off I can do this fix in the fall. I'm afraid if I tear anything apart I may be down and out for a few weeks.
    jim
    jim is offline
    Senior Member jim's Avatar
    Indio, CA
    100
    I never turn my gas off, it does not leak and starts right up when I am ready to go, I guess if I was going to store it for awhile it would be a good idea to turn it off
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    FL. GA, NC
    2,392
    If it's a small puddle (as in the picture above) and if the gas is coming from the hose at the bottom of the carb bowl, then the most likely cause is the o-ring on the carb float valve seat:
    Replacing the o-ring is not difficult, but does take patience and care to do it without causing damage.
    I do not wish to encourage you to do the job if you feel uncomfortable doing it.
    There is the potential for breaking or losing parts during the process.
    On the other hand, a dealer will charge a lot of $$$ to replace a 25 cent o-ring.
    Here's the link to the manual. I believe the carb removal for the TK carb is in the supplement.
    Manuals
    https://tw200forum.com/index.php?/top...epair-manuals/
    Here's what's involved:
    Remove the carb from the bike.
    Remove the bowl from the bottom of the carb.
    Remove the float, and the valve seat.
    Replace the o-ring.
    Then reassemble.
    Also Yamaha will not sell just the o-ring. You have to purchase the valve, valve seat, and o-ring as a set.
    I don't remember if you posted what year your TW is. If it's a 2001 or newer, I have extra o-rings. I don't know if they will fit the TW's before 2001.
    If all this scares you, you can ride your TW the way it is, remembering to turn off the petcock every time your park.
    jb
    Junior Member philp38's Avatar
    Decatur TN
    16
    Quote Originally Posted by jbfla View Post
    Manuals
    Replace the o-ring.
    Then reassemble.
    jb
    I'm glad we have this TW 200 Forum. I just picked up a 2003 with low mileage and have cleaned the carb and adj the float setting with no luck. It seems I also need to order valve seat set. I also had fuel in the oil. I have changed the oil and will again after I run it a few miles.
  1. Tool Pool.
    By lizrdbrth in forum Off-Topic
    Last Post: 01-21-2012, 03:32 PM
gas pooling under tw200
