ttr225 header
Results 1 to 5 of 5
Thread: ttr225 header
    Junior Member kripton's Avatar
    May 2011
    san diego calif.
    26
    hey does anybody know if ttr225 header fits t-dub 2002
    Devon, England.
    614
    Quote Originally Posted by t -bone View Post
    Yes. If you trim an inch or so off the silencer end.
    Senior Member trailboss's Avatar
    Sep 2010
    Alexandria VA.
    140
    All the threads I've read on the TTR header this is the first I've heard that you need to cut the header is this true? I'm thinkin of getting one and would like to know rather than fin out the hard way.
    Devon, England.
    614
    Quote Originally Posted by 73 Trailboss View Post
    The TTR header bolts straight on at the cylinder head and follows the same lines as the TW header but when you come to put on the standard silencer (or muffler) you will find that the TTR header is a bit longer and needs to have about 1 to 1 1/2 inch cut off.
    It's an easy enough job.
    May 2011
    san diego calif.
    26
    sweet im geting one thanks.
  1. Installing TTR225 clutch
    By yz250f4ever in forum Technical Help
    Last Post: 01-24-2013, 09:10 AM
  2. ttr225 motor in a tw?
    By stan in forum Technical Help
    Last Post: 11-28-2012, 06:28 PM
  3. TTR 225 header
    By emilliano in forum Performance and Customization
    Last Post: 04-14-2012, 10:17 AM
  4. TTR225 engine in a TW200, extended front sprocket shaft?
    By Skullhag in forum Performance and Customization
    Last Post: 05-01-2011, 06:27 PM
  5. ttr225 piston in a tw200 cylinder
    By racerx in forum Performance and Customization
    Last Post: 08-18-2010, 03:22 PM
ttr 225 header on a tw 200
