1994 tw when you gun it real hard it grinds
Results 1 to 4 of 4
    Member Daltoncoody's Avatar
    Apr 2011
    Arkansas
    58
    Hey yall. Got a 94 with stock chain and sprockets. Seems like when you turn to the side and gas it that it slips. Kind of like chain slipping not really a clutch sound but sounds like chain or front sprocket. Any ideas would really help
    BC
    537
    My guess is that you're missing a few teeth...probably on the FRONT sprocket. Either that or it's in really bad shape.
    Don't run it any longer until you can have a look at it.
    You can see the front sprocket without having to remove the engine casing. Feel the teeth...if you can cut yourself on them, they're worn!
    Normal sprocket teeth are dull and thick. Worn teeth get pointy with sharp edges. Check the play in the chain at the rear sprocket...I suspect that ALL three probably need replacing.
    Visit my Blog...Hidden Content or my YouTube channel: Hidden Content
    Apr 2011
    Arkansas
    58
    Yea i am pretty sure that it needs them all changed. What is better. I am mainly going offroad and some back roads in between. Dont want it too low geared. What about a 15/50 setup
    Ephrata, WA
    1,125
    If you want only off road I'd say 14/55, but I like the torque. Stock 14/50 should be fine for you if you want to go mainly off road. With the 14/55 setup you can go 55 mph, but it purrs at 35-40. It all depends on where you ride and what you ride on. If you are only on gravel roads, then the 14/50 will be great, but for a combo of gravel roads and some nasty roads, I prefer the 14/55.
    Oh, and if you have a 94 with stock sprockets and chain, its time to get new sprockets and chain no questions asked.
    1990 TW200
  1. 1994 TW200 Rebuild
    By P.ortega in forum Performance and Customization
    Last Post: 06-20-2013, 08:27 AM
  2. 1994 oem seat cover
    By joeband in forum TW200 Classifieds
    Last Post: 01-03-2012, 02:50 PM
  3. Carburetor Style of 1994 TW
    By dakman74 in forum Performance and Customization
    Last Post: 08-17-2011, 07:41 AM
  4. Real cheap and durable hard storage
    By jontow in forum Performance and Customization
    Last Post: 06-10-2011, 08:02 PM
  5. 1994 TW200 in Austin
    By JarrodWeaver in forum TW200 Classifieds
    Last Post: 02-07-2011, 06:00 PM
