60 tooth sprocket HELP
Results 1 to 9 of 9
    Junior Member cthunter's Avatar
    May 2011
    26
    I just ordered a 60 tooth rear sprocket. What length 428 chain do I need?
    I did the calculator and it said 112 links. I know that's not right.
    Desert, SoCal
    7,369
    Quote Originally Posted by cthunter View Post
    You're correct. Stock is 122. I use 128 for a 14/55 combo, so I'm guessing you'll need at least a 136-138 for a 60.
    Ephrata, WA
    1,125
    Try this:
    Sprocket/Chain Calculator
    I took off a 126 link chain for my 14/55 setup and replaced it with a 124 link chain. You'll find that a couple lengths will work.
    1990 TW200
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    For me,
    14/60 "128 links" is the correct size (measure) ..!
    Ephrata, WA
    1,125
    christddel is right on. Plug the variables into a sprocket/chain calculator and you'll get 127 and a remainder, so round up and a 128 link chain will be just fine.
    1990 TW200
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    This is short and sweet. With Christddel post we have it all. Think this should be made a sticky if we don't already have the formula. Gerry
    Take care my Friend.........
    Desert, SoCal
    7,369
    I'm a moron. I guesstimated yours with the same axle setback I use with my ATV tire.
    I calculated it by center-to-center distance and got 128 as well.
    I'd buy it long, in any case. Slide the axle as far forward as possible with no weight on the bike, see where the links fall in the real world with proper slack, then break the chain.
    May 2011
    26
    You guys are great. The 128 chain fit the 60 tooth sprocket perfectly. Thanks to all.
    Member hoginthebog's Avatar
    May 2011
    50
    Hey, CTHunter. Can you link to the sprocket and chain you ordered?
    TIA
  1. Replies: 0
  2. 13 tooth sprocket
    By PalmStateCrawler in forum Technical Help
    Last Post: 12-12-2011, 10:28 PM
  3. 47 tooth sprocket
    By mga60tw in forum General Discussion
    Last Post: 10-07-2010, 11:31 PM
  4. 47 Tooth Sprocket
    By FnMag in forum Performance and Customization
    Last Post: 08-26-2010, 12:26 PM
  5. 13 tooth sprocket
    By Honda710 in forum General Discussion
    Last Post: 08-19-2010, 08:17 AM
55 tooth rear sprocket
60 t rear sprocket
60 tooth rear sprocket for a tw200
60 tooth sprocket
60 tooth sprocket for yamaha tw 200
how many links chain will fit a 60 tooth sprocket
is the 60 tooth sprocket noticable
sprocket specialists tw200 65 tooth
tw200 55 vs 60 teeth sprocket
tw200 60 tooth sprocket
yamaha tw 200 60tooth sprocket
yamaha tw200 sprockets 60tooth
