carrier
Results 1 to 7 of 7
Thread: carrier
    Junior Member 36Ketch's Avatar
    Jun 2011
    6
    Hi all: Has anyone found a suitable trailer hitch carrier for our TW's big tires? Wanna put it on the back of my RV Thanks Kim in Arizona
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    The only thing I can offer is for you to go to this site: www.advrider.com,,,,,,,,go to the thumper section and search the tw200 thread.T'm new here...not to bikes in general.Can not seem to find alot of general bike info on this forum??????takes awhile...this includes the other:tw200formotion.
    Pleasanton, CA
    5,682
    Hi Kim,
    Versahaul make a high quality carrier that should work well for the TW. The side walls of the carrier rail are angled outward to accommodate wider tires. It is very heavy duty and expensive compared to many other carriers, but is well built and has some nice features like retractable tie down points, etc.
    Brian
    Member bend42's Avatar
    86
    Quote Originally Posted by Kim View Post
    Several riders, both here and on ExPo Forum, myself included, have been using an "Ultmate MX Hauler". Slips into a standard receiver and uses a small bottle jack to lift a platform under your engine [best if you beef up the stock skid plate]. I like mine very much, loading and unloading my TW several times a week. Prefer to drive my bike to the dirt rather than ride pavement very much.
    John
    Senior Member rm_hm's Avatar
    1,619
    Search Results
    1. Hitch Mounted M/C Carrier ? - Yamaha TW200 Trailway Discussion Forum
      25 posts - 16 authors - Last post: May 10, 2008I'm looking for a Hitch Mounted Motorcycle Carrier. There are many designs out there some good some bad. I searched here and found someone ...
      tw200forum.com › ... › Hitch Mounted M/C Carrier ? - Cached
    2. bike carrier - Yamaha TW200 Trailway Discussion Forum
      7 posts - 4 authors - Last post: Oct 10, 2007Does anyone know of a motorcycle carrier that will attach to a standard 4 inch square bumper on a camper? I've found pleanty for a receiver ...
      tw200forum.com › ... › TW200 ForumsTW200 General D... - Cached
    3. motorcycle tow bar carrier - Yamaha TW200 Trailway Discussion Forum
      Jun 28, 2007 ... My self I use a regular hitch carrier 60" long I got at Lowe's for $55.00. Drilled and tapped my receiver for a bolt to stop the rack from ...
    4. Rear Hitch Bike Carrier - Yamaha TW200 Trailway Discussion Forum
      15 posts - 7 authors - Last post: Oct 11, 2008What brand of rear hitch bike carriers are you folks using out there that are of good quality ? And are the wide TW tires a problem for the ...
    5. Tow Behind Carrier - Yamaha TW200 Trailway Discussion Forum
      6 posts - 4 authors - Last post: Sep 24, 2009Right now I use a hitch mounted carrier to haul the TW. This is the kind where the bike is on the back of the truck, parallel to the ...
      tw200forum.com › ... › TW200 ForumsTW200 Technical... - Cached
    6. Atlas Motorcycle Carrier - Yamaha TW200 Trailway Discussion Forum
      5 posts - 3 authors - Last post: Apr 28, 2008Has anyone used one of these Atlas Motorcycle Carrier With Ramp. It is less than half the cost of a versa haul. What I like is able to pull ...
    7. AMC 400 hitch bike carrier lighting/plug/wiring - Yamaha TW200 ...
      4 posts - 3 authors - Last post: Apr 30, 2009I need to equip my hitch bike carrier with some lighting since my TW covers up the vehicle turn/brake signals when loaded. ...
    8. Trailer Hitch carrier - Yamaha TW200 Trailway Discussion Forum
      2 posts - 1 author - Last post: Nov 4, 2008Trailer Hitch carrier ... Trailer Hitch carrier. (please select), Forums Home, |- Search Forums, |- Active Topics, |- Unanswered Posts ...
    9. motorcycle tow bar carrier - Yamaha TW200 Trailway Discussion Forum
      7 posts - 5 authors - Last post: May 5, 2008However I may paint a note on the side of the carrier to remind me to lash in the future. That huge rear tire really sits up high on the ...
      tw200forum.com › ... › TW200 General D...motorcycle tow bar carrier - Cached
    10. Re: Motorcycle Carrier, how wide is the TW rear tire? - Yamaha ...
      5 posts - 3 authors - Last post: Jun 17, 2008Motorcycle Carrier, how wide is the TW rear tire? ... http://cgi.ebay.com/...ors/MOTORCYCLE-CARRIER-RACK-RAMP-TRAILER-HITCH- ...
    1. Re: Motorcycle carrier lock - Yamaha TW200 Trailway Discussion Forum
      16 posts - 9 authors - Last post: May 27, 2010I already have a pretty solid lock for the carrier to the vehicle I just can't decide on a good lock for the tw to the carrier itself. ...
    2. Re: My new carrier.... - Yamaha TW200 Trailway Discussion Forum
      21 posts - 10 authors - Last post: Apr 24, 2008My new carrier.... Attachment: Picture 001 (600 x 450).jpg .... Re: My new carrier.... Attachment: gas.jpg ...
    3. Combo bike rack and hi-vis carrier - Yamaha TW200 Trailway ...
      2 posts - 1 author - Last post: Nov 25, 2007Just so you don't think we Canadians are technically challenged here is my bike and racks for Rving. ...
      tw200forum.com › ... › TW200 ForumsTW200 Performan... - Cached
    4. Re: So Stupid I Had to Share - Yamaha TW200 Trailway Discussion Forum
      Jun 10, 2010 ... Anyway, after riding the weekend, I go to load the bike on my hitch mounted carrier. I get it up there without too much problem, ...
    5. Re: Unity, OR OFD camping - Yamaha TW200 Trailway Discussion Forum
      26 posts - 8 authors - Last post: Jun 23, 2010If you have a pic of the back of the trailer with the bike on the carrier, pls post it. Looks like nice country. ...
      tw200forum.com › ... › TW200 ForumsTrails, Offroad... - Cached
    6. Re: New member looking at a TW - Yamaha TW200 Trailway Discussion ...
      16 posts - 7 authors - Last post: Feb 25, 2010Regarding the bike carrier... I have a standard hitch mounted carrier that I use with my motorhome. No problem with the fat tire. ...
    7. new member, old TW checking in - Yamaha TW200 Trailway Discussion ...
      12 posts - 8 authors - Last post: Jul 19, 2007Anyhow, the TW is what I wanted, will need to fab a rear carrier for my ... Syncro, The TW will fit on a standard 60" cargo hitch carrier. ...
    8. Put the Hitch haul on - Yamaha TW200 Trailway Discussion Forum
      27 posts - 12 authors - Last post: Jun 12, 2007We are planning on getting a hitch mounted carrier for our TW but have not been able to decide on best unit and best buy for the money. ...
    9. Hauling TW on Truck or Camper - Yamaha TW200 Trailway Discussion Forum
      27 posts - 13 authors - Last post: Sep 17, 2009You could modify a motorcycle trailer hitch carrier, to bolt onto the tongue. When the trailer is not hooked to the truck, you could use the ...
    I have a versa hauler with a light kit and I just bought this for moving the TW and my daughter's quad....
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Quote Originally Posted by Rich View Post
    Sigh......
    Rich, you must resign yourself to being the master of the TW search.
    jb
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Seek and Ye shall find...... though sometimes it is harder than others. Thanks Rich.
    Take care my Friend.........
  1. Sidecar motorcycle carrier
    By MrDNA in forum General Discussion
    Last Post: 01-13-2013, 09:30 PM
  2. Motorcycle carrier
    By bondfast in forum Performance and Customization
    Last Post: 10-22-2012, 01:03 PM
  3. My Bike Carrier Rox ;)
    By RodneyBR in forum General Discussion
    Last Post: 08-14-2011, 01:41 AM
  4. I Bought A Hitch Carrier!
    By Kev250R in forum General Discussion
    Last Post: 05-05-2011, 05:48 PM
  5. OEM Carrier ***SOLD***
    By eaglescall in forum TW200 Classifieds
    Last Post: 09-10-2010, 10:25 PM
tw200camperrearbumpercarrier
