timing chain
Results 1 to 2 of 2
Thread: timing chain
    Junior Member maupin81's Avatar
    May 2011
    22
    i hear a tick on the left side of the motor after running for a while how do i know when to adjust the timing chain tensioner and how to do it thanks.
    Ephrata, WA
    1,125
    What year is your TW? 87-00 bikes have a manual adjuster, while 01-present bikes have an automatic adjuster. Download the manual and follow the directions. Its not very difficult or time consuming to do.
    1990 TW200
  1. cam timing to TDC
    By jimbo slice in forum Technical Help
    Last Post: 07-14-2014, 08:47 PM
  2. Timing chain adjustment help
    By kevorwaller in forum Technical Help
    Last Post: 04-15-2014, 09:57 AM
  3. TW Timing
    By SirSmighty in forum Technical Help
    Last Post: 10-06-2011, 01:23 AM
  4. Checking new style timing chain tensioner
    By RockyTFS in forum Technical Help
    Last Post: 05-16-2011, 05:27 AM
  5. timing chain adjustment
    By bluedevilfootballman in forum Technical Help
    Last Post: 08-07-2010, 09:13 PM
how do you set timing on a yamaha tw200
how to adjust a cam chain on a yamaha tw200
how to set cam timing 1987 yamaha tw200
how to set timing on a1996 yamaha tw200
timing adjustments for a 1987 yamaha tw 200
timing gear for yamaha tw200
timing mark on yamaha tw 200
yamaha tw 200 ing timing marks
yamaha tw 200 timing set
yamaha1990tw200timing
