Unknown Rubber Part
Results 1 to 10 of 11
    Member ravenwoods's Avatar
    Jun 2011
    34
    I've got an XT200 (1982), same engine as the TW200. Other than the engine, not much is the same, so I'm not sure anyone will be able to help. I took off the seat, air filter box, gas tank. Then I notice this rubber part lying on the ground. I can't figure out where it came from. Any Ideas?
    Photo of Part
    Hmmm? Not a clue. I'm guessing here, but maybe a pad to prevent squeaking where the seat rests on the frame?
    540
    my swag is a rubber bumper/damper, look around for a slot that looks like it will accommidate the thinner side or look for something that has a rub mark on it like the fatter side
    Desert, SoCal
    7,369
    Believe it or not, it goes on the lower headlight mount. How it got under your seat is anyone's guess.
    Jun 2011
    34
    Thanks! I'll see if I can find a place for it there. It would be funny if the lower headlight mount already has one, and that this one is one they lost at the factory and only got found now.
    Desert, SoCal
    7,369
    If yours has the round headlight, disregard. If it has the square one, the grommet goes fat side down on the underside of your headlight bezel then slips over a tab on the fork-mounted headlight bracket. Tw's and XT250's, 350's and 600's have the same grommet. They're usually long gone.
    Jun 2011
    34
    I just looked at a parts diagram for the headlight of my XT200 and I do not see it there. I'll inspect the XT200 when I get home this evening and see if it indeed goes there somewhere.
    Jun 2011
    34
    Mine has a round headlight.
    Senior Member jontow's Avatar
    Oct 2010
    Potsdam, NY
    701
    How about I throw another spin on this, which is a more likely candidate: I have lots of these show up in my driveway.
    Pick whichever car you own that has drum brakes in the rear, and put the rubber part (inspection/adjustment plug) back in the drum backing plate before you ruin your brakes or lose the plug
    1997 TW, well loved, a bit modified.
    Jun 2011
    34
    Quote Originally Posted by jontow View Post
    You solved the mystery! My Subaru Forester has disc brakes on front and back, but the parking brake is a drum brake. A few weeks ago I replaced the wheel bearing on the right back wheel. by removing that little grommet you can adjust your parking brakes. That little grommet has been lying on the floor unseen until I take apart my XT200. Thanks for your good eye.
  1. Rubber Windscreen - and Rubber on Cyclerack
    By APV1 in forum Performance and Customization
    Last Post: 11-12-2012, 06:54 PM
  2. Rubber Foot Pegs
    By lyfestyl in forum General Discussion
    Last Post: 08-15-2012, 09:23 AM
  3. Replies: 12
    Last Post: 07-27-2012, 07:52 PM
  4. Need: Rear fender rubber pad thingy
    By vn_grnt in forum TW200 Classifieds
    Last Post: 04-06-2012, 04:19 PM
  5. Butyl vs. Natural Rubber tubes
    By drake523 in forum Technical Help
    Last Post: 03-09-2012, 05:51 PM
xt200 forks
