Countershaft Seal/Bearing
Results 1 to 7 of 7
    Junior Member tickboy's Avatar
    20
    Hi,
    After removing the countershaft seal I noticed the bearing seemed a little "pushed in". Is this possible? I may have put some pressure on it while removing the seal.
    Also, how do I get the new seal past the countershaft splines without ruining it?
    Thanks
    Coat the seal and splines with clean oil, and be very careful.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    Also see if you can't find some pvc or metal pipe of the correct size to act as a driver. That way the chances of installing the seal crooked is much reduced.
    20
    Cool, thanks for the tips.
    6,984
    Your bearing looks OK to me. Don't worry about it.
    Replace the outer seal too, along with the shift shaft seal. Do them all at once and be done with it.
    I put Scotch Tape on my splines, covered with a little oil, and it slipped right on.
    20
    Quote Originally Posted by Tony View Post
    Thanks Tony, Scotch tape sounds like a good idea.
    Quote Originally Posted by tickboy View Post
    +2 on the Scotch tape. Sounds like a good idea. Tdub is leaking from one, maybe both of the countershaft seals. I have new seals, bearings, and gasket ready to go, and I've been waiting 6,500 miles for the chain and sprockets to wear out so I can replace everything at the same time. Frickin o-ring chains never wear out when you need them to--only 25,000 miles or so on this chain and still going strong.
  1. Outer countershaft seal
    By howardgene63 in forum General Discussion
    Last Post: 08-12-2014, 01:34 AM
  2. All Balls steering bearing conversion
    By silverhead in forum Performance and Customization
    Last Post: 04-28-2013, 08:13 AM
  3. ball bearing camshaft--anybody tried this?
    By JungleBiker in forum Technical Help
    Last Post: 04-08-2012, 07:11 PM
  4. Steering bearing replacement
    By Rainman in forum Technical Help
    Last Post: 02-21-2012, 05:12 PM
  5. tips to getting inner countershaft sprocket seal out?
    By triple3jrb in forum Technical Help
    Last Post: 02-21-2012, 03:53 PM
countershaft seal parts diagram tw 200
how to remove tw200 countershaft berring
new countershaft tw200
tw200 countershaft seal
tw200 countershaft seal part number
