Do I need to re-jet my carb?
Results 1 to 5 of 5
    Member Homeskool's Avatar
    Jan 2011
    82
    Question!
    I just removed my airbox and installed a K&N air filter and oil filter.
    It was a kit I ordered that also came with the "batter lesser" module to wire in to remove the battery.
    It also came with a re-jeting kit for the carb.
    What will happen if I don't re-jet?
    I have not "run" the bike yet because I don't know what will happen if I run the bike before I install
    this re-jet kit. Someone told me the bike would get very hot cuz it can breath more?
    I don't want to do it if it is not necessary.
    But I totally think I have too otherwise why would they include it in the "kit"
    Any information would be great!
    Thanks!
    866
    Quote Originally Posted by Homeskool View Post
    What will happen if I don't re-jet?!
    Your bike will run lean. Go ahead and use the kit, it's a fairly simple process and your bike will run much better.
    Jan 2011
    82
    Thanks for your input!
    Is there any harm in running the bike lean for a few days until I get around to rejetting it?
    Does my friend have any validity to his statment about it causeing the bike to overheat and burn out seals?
    There is a sticky on carb jetting in this forum topic. In it you will find the typical symptoms of bad carb tune. No symptoms, no need to rejet. Got symptoms, rejet. Running lean can cause heat-related problems, such as holed piston, burned valve, engine seizure, and other bad stuff. Running rich can lead to carbon buildup in the combustion chamber, clogged muffler baffles, fouled spark plug, oil washed from cylinder walls leading to excessive wear and loss of compression, and other bad stuff. Running a bike with a messed up carb tune will make your mechasnic wealthy.
    Jan 2011
    82
    Thank you a ton for your information qwerty, I won't run the bike until I re-jet. I will read everything on the sticky once I locate it.
    Thanks kindly!
  1. Is the OEM carb a Mikuni carb?
    By macbig2k1 in forum Technical Help
    Last Post: 01-29-2013, 05:50 PM
  2. Newer CV carb vs. older carb. MPG
    By number356 in forum Technical Help
    Last Post: 03-28-2011, 11:25 AM
do i need to rejet my carb
does bad carb jetting burn oil
how do i know if i need to jet my carb
rejettig tw200
rejetting tw200
tw 200 jet kit
tw200 rejet kit
when do i need to jet my carb
why does my tw200 run bad
why re jet carbs
