TW no start
Results 1 to 2 of 2
Thread: TW no start
    Senior Member immgunn's Avatar
    Sacramento, CA
    172
    Came home from work Friday. A short while later, I needed to run an errand. I hopped on the TW -- no start! No headlight, no nothing. Battery voltage good. No power to starter solenoid.
    Next day. Removed headlight bezel/fairing. Removed instrument panel. Remove headlight support. Removed ignition switch. This is what I found...
    I soldered the power wire back onto the lug of the ignition switch.
    Re-assembled. Works fine. Problem fixed.
    I have no idea why the wire separated from the switch other than a faulty solder from the factory. Denise (wife) theorizes that it's due to a theft of the bike several months ago (we're going to court 7/12).
    Who cares. 30 minutes of diagnostics and repairs. Pennies to solder the broken connection. I'm back on the road again.
    Life is good!
    866
    Nice job immgunn. It sounds like you're a "can do" kind of guy.
  1. Start but no start - please help -
    By rtf in forum Technical Help
    Last Post: 05-23-2013, 08:24 PM
  2. TW won't start
    By Vlakslee in forum Technical Help
    Last Post: 09-28-2011, 02:40 PM
  3. Won't start but will???
    By Lido in forum Technical Help
    Last Post: 09-12-2011, 07:37 PM
  4. kick start won't start
    Last Post: 01-15-2011, 05:23 AM
  5. TW won't start?
    By rolo in forum Technical Help
    Last Post: 10-28-2010, 05:05 PM
