Aftermarket oil filters
Results 1 to 5 of 5
    Junior Member dennism's Avatar
    Jun 2011
    24
    The nearest Yamaha dealer is over 50 miles away from me. Is it OK to use an aftermarket oil filter for the TW200 instead of the OEM part number 5HO-13440-09-00 ?
    If the answer is yes, does anyone have suggestions as to a high quality replacement part?
    Thanks for your help.
    866
    Quote Originally Posted by dennism View Post
    Yes, aftermarket is fine. Just make sure you compare the slots and holes on the end to those of the stock filter and make sure they are the same. Then use the oil check bolt on the head to ensure oil flow after installation.
    I've been using the bikemaster brand on my TW. I got mine from Chaparral, but I'm sure there are plenty of other sources.
    http://www.chaparral-racing.com/Prod...model=TW%20200
    Devon, England.
    614
    Hiflo filters are good quality.
    They meet the very tough German TUV standard.
    Hiflo hf143 is the one for TW's.
    jim
    jim is offline
    Senior Member jim's Avatar
    Indio, CA
    100
    The filter on my 2002, is made of wire screen I just wash it out and use it again
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    Now where can you get them for Wal-Mart prices?
  1. Fuel Filters?
    By Swamp in forum Technical Help
    Last Post: 05-02-2013, 03:14 AM
  2. Which air filters for a TW125
    By seba in forum Performance and Customization
    Last Post: 04-27-2013, 12:11 PM
  3. So I want the 2 cone air filters
    By chevyy1212 in forum Technical Help
    Last Post: 12-18-2011, 07:40 PM
  4. K&N oil filters anybody use them
    By HDLLLIII in forum Technical Help
    Last Post: 09-27-2011, 02:27 PM
  5. Re-usable oil filters?
    By UKJ in forum Technical Help
    Last Post: 01-01-2011, 05:13 PM
