Black surface coating inside the crankcase bubbling/peeling ?
Results 1 to 10 of 13
    Junior Member georgelewisray's Avatar
    Oct 2010
    Cape Fear, NC, USA
    16
    Dear Abbey,
    There is a black surface coating like paint inside my TW200 2007 right side crankcase that in some places is bubbling and peeling like a paint coating attacked by solvents.
    It is only on the aluminum case surface and not on any of the gears or other parts.
    Can you shed some light on what this coating is and if softening bubbling has happened to anyone else and what are the ramifications, ... like clogging oil galleys?
    My expectation would be to find no coating on the aluminum except whatever gum, varnish, tars are pretty normal inside any engine.
    I guess if it comes down to it I will try to be happy about learning how to do a full engine teardown and clean out the loose coating, YUCK!
    I'm finding almost nothing about interior crankcase coatings on numerous GOOGLE searches.
    signed,
    Puzzled in Cape Fear
    Details:
    I have just started a kick starter install on a 2007. The bike had gas in the crankcase for maybe two months while I was off on a yacht delivery ( I used to have the bad habit of leaving gas petcock on, not now! ). Thank goodness it wouldn't start when I got back and that was a big mystery so it sat for a couple more weeks. It also had a new little oil drip and it took me a long time to figure out the new little crankcase oil drip smelled of gas.
    LIGHTS GO OFF, BELLS RING, BUZZER SOUNDS !!!!! carb dumped the whole fuel tank into the engine
    This seemed like a good time do the kick starter install as I have been hanging on to the parts for about a year waiting to get some spare time.
    Clean Oil, Fresh Gas, Spark Check and Thumper fired right up and idled for a bit to get oil circulating watching the whole time in the oil sight glass to see that the pump is picking up the oil and watch it drip back into the sump.
    Pull off the right crankcase cover and start to pull the clutch and about then I notice the interior of the crankcase is painted or powercoated or something and that there are a number of places where the coating is bubbled and not well adhered . . . .. what a drag .... what about all the other places in the crankcase I can't see that must have loose coating waiting to gum and clog up the works. I am afraid a full teardown may be called for. Hard to imagine Yamaha will cover this but it seems negligent on their part to use a coating that will come off and gum up the works.
    Cape Fear, NC, USA
    Desert, SoCal
    7,369
    It's probable that the combination of the gas and oil being left in the crank case are the culprit. No doubt the ethanol in our gas was a contributing factor.
    I doubt the cases themselves have powdercoating on their interior surfaces, but Yamaha gets pretty sloppy with the side covers. If I'm right you could remove only thje side covers, fully eliminate any remaining paint from their interiors, flush the crankcase thouroughly, then refill and do a couple of oil changes back-to-back.
    Definitely a new one on me. Does what you're seeing inside the cases appear to be softened powdercoating? Check your clutch before doing anything else. The binder in the clutches breaks down with prolonged gas exposure as well.
    Devon, England.
    614
    The inside of the inner crank cases of my TW125 engines are painted black, but the clutch and generator covers are not, there was no evidence of this peeling when I split them for my 200cc and 225cc conversions.
    The XT225 engines i have split were not painted inside.
    Desert, SoCal
    7,369
    What were they thinking?
    Must be a late-model thing. I've not seen it on any of my older bikes yet.
    Tdub has bare surfaces inside. 2003
    Oct 2010
    Cape Fear, NC, USA
    16
    Thanks for the feedback, I'll get some pictures posted in near future.
    Also think I need to contact Yamaha to see what this stuff is .... anyone suggest a phone# for tech support in the USA ?
    Cape Fear, NC, USA
    Devon, England.
    614
    It looks like just normal engine paint to me.
    My memory was a bit fuzzy so I checked some old casing and the inside of the inner cases have heavy over spray rather than a full coat of paint.
    Oct 2010
    Cape Fear, NC, USA
    16
    THAT'S IT !!!
    What the heck is it doing in there?
    Seems stupid, what's the point ?
    A stuck carb float and soaking in gas for a while can soften it and then ??????????
    Cape Fear, NC, USA
    Senior Member immgunn's Avatar
    Sacramento, CA
    172
    We used to paint the inside surfaces of cast iron automotive cylinder heads and block galleys with rustoleum to prevent sludge build-up.
    Desert, SoCal
    7,369
    Quote Originally Posted by immgunn View Post
    A V8 could swallow an elephant through its oil passages, and if not it had an oil filter the size of yer head.
    I'd love to hear what prompted Yamaha to risk this on a munchkin motor.
  1. Pressure in crankcase?
    Last Post: 09-19-2012, 05:51 AM
  2. Black plastic off a 2006 TW & Black seat cover
    By Mini-Mac in forum TW200 Classifieds
    Last Post: 11-06-2011, 12:32 PM
  3. Crankcase swap
    By Richb in forum Performance and Customization
    Last Post: 01-05-2011, 10:27 AM
  4. Lots of fuel in crankcase.
    By 311unity13b in forum Technical Help
    Last Post: 09-19-2010, 03:58 PM
  5. wtb crankcase cover
    By jughead919 in forum TW200 Classifieds
    Last Post: 09-06-2010, 09:29 PM
beegblak cok
beeger beeg blak
crankcase coating
crankcase coatings
crankcase inside flaking
powder coating inside the crankcase
what oil in crank case cover in on yamaha tw 200
why would anyone paint the inside crankcase of an engine
