Stator Function
Results 1 to 4 of 4
Thread: Stator Function
    Junior Member jmurray's Avatar
    Jul 2011
    4
    Hello: I have a 1994 with a bad stator. Is the stator used for anything besides charging the battery? In other words, if I can lve without the electric start, do I have to replace the $300+ stator? The bike is worth about $1200. I hate to spend 1/3 the value on a stator.
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    The stator is an alternator that has the magnets rotating around stationary pieces, instead of as in a car or truck.
    The "pieces" are the charging system for the battery, and more importantly, another set for the ignition.
    I have read on the Forum of taking off the starter, battery, and adding a sink of sorts so as not to damage the
    charging system.(Start it with your hind leg.) I have to run off to work; hate to be so terse, but stators can be rewound
    for much less. I have one waiting on it and I am afraid my '89 is insisting on it, and this is after only a 1000 miles
    on a new one. Have you done the resistance checks? Is the battery chargeable? Any pinched wires? Read Sloppy's post
    from the other day-- that's us, and I am not charging since. Someone better will be along shortly.
    GB
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    Regards...Wes
    Jul 2011
    4
    Quote Originally Posted by vuldub View Post
    Thank you
  1. 1993 Stator
    By trailscout in forum Technical Help
    Last Post: 03-07-2013, 07:50 AM
  2. stator and pulse
    By vincentdsnt in forum Technical Help
    Last Post: 06-09-2012, 07:54 AM
  3. need c.d.i. and stator for 88 tw
    By ranger11 in forum TW200 Classifieds
    Last Post: 04-18-2012, 05:26 PM
  4. Anyone using the cheap 5-Function Volt Meter?
    By MrDNA in forum Technical Help
    Last Post: 10-18-2011, 10:27 AM
  5. Bad Stator????
    By dbreinich in forum Technical Help
    Last Post: 03-14-2011, 12:15 AM
stator function
tw200 stator
