Swingarm Removal
Results 1 to 3 of 3
    Senior Member ezman671's Avatar
    Jul 2011
    Spacecoast, FL
    178
    Going to remove my swingarm to deal with some rust issues and replace the plastic chain guard.
    What issues will I have with the shock extending and being very difficult to reinsert?
    Is the shock under a lot of compression at rest with the tire removed.
    Do not want to undo the bolt and have it fly apart.
    866
    Shock is not under any compression with wheel removed (and bike off of ground). No worries of flying shock.
    Jul 2011
    Spacecoast, FL
    178
    Wow! My first post and I get an answer in less than 10 minutes.
    Thank You!
    Now back to work.
  1. Air box removal
    By neimang in forum Performance and Customization
    Last Post: 09-18-2014, 01:17 PM
  2. Camshaft removal
    By fredzaha in forum Technical Help
    Last Post: 06-23-2013, 09:03 PM
  3. Air box removal
    By neimang in forum Technical Help
    Last Post: 06-21-2013, 10:27 AM
  4. Tank removal
    By Deldog in forum Technical Help
    Last Post: 06-16-2013, 07:20 AM
  5. decals removal
    By glassyandsunny in forum General Discussion
    Last Post: 05-08-2013, 02:09 PM
