how often do you overhaul the engine?
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Mike Mecredy
Thread: how often do you overhaul the engine?
    Junior Member Mike Mecredy's Avatar
    Jul 2011
    Rupert Idaho
    26
    Hi, my 1991 has about 10500 miles on it, it still seems to have plenty of spunk, but how long until I can plan on rebuilding the engine, providingin everthing works right, and it's normal wear?
    owensexport likes this.
    Devon, England.
    614
    Qwerty of this parish has well over 40,000 miles on his original engine.
    Look after the maintenance, use good quality oil and service parts and the bike will run and run and run.
    Tdub has over 47,000 miles. Runs fine. Good power. Always has used a bit of oil, especially screaming done the highway at 65-70mph drafting SUVs. Uses a bit more oil since my son borrowed her and rode 3 days without checking the oil--got her back and couldn't see anything in the window. That was 31,000 miles ago. Now she's leaking a bit more oil from the countershaft sprocket area. She's about due for a chain and sprocket set (26,000+ miles on the parts on the bike) and she'll get both seals at the same time. Also some weeping out of the valve covers, she'll get new rings at the next valve check.
    Junior Member mike438's Avatar
    Mar 2011
    6
    i have a 1991 tw. had it now for 10 years bought it with 6000 miles on it. this summer it rooled over 21000. pulled the head off just to see what the cylinder walls look like in it and you can still see the cross hatch in it from factory. now i ride it pretty hard and put heavy oil in it. i use amzoil 20w50 and change it every 1000mi. i also pull the carb off every winter and do a good healthy service on it. i have 15/43 sprockets on it and she cruises like a dream on the highway. i dont take it over 70 like everybody says just because of vibrations. just keep the carb and valves in check and put good oil in it and she will be alright
    Another succesful user of ester-based synthetic motorcycle oil.
    866
    I'm running Rotella T from Wally and Company. I've got just over 4000 miles and I've only had to re-ring once.
    Lol, jk. I'm using M1 V-Twin when it's really hot and M1 Racing 4T the rest of the time. I'm hoping I can one day get to 47000, although that's a long row to hoe on a T-Dub.
    Senior Member longroof's Avatar
    Crossville, TN
    257
    42,000+ miles on origional engine
  1. How much will you pay for a TW 225 engine?
    By RisingSun in forum General Discussion
    Last Post: 07-02-2013, 12:17 PM
  2. engine oil....
    By zoomer in forum Technical Help
    Last Post: 06-14-2013, 02:18 PM
  3. Value of the engine?
    By Frank Colver in forum General Discussion
    Last Post: 02-24-2013, 02:02 PM
  4. Can't rev engine.
    By pedroenespana in forum Technical Help
    Last Post: 08-31-2012, 12:36 PM
  5. engine oil q's
    By Henrici in forum Technical Help
    Last Post: 04-23-2011, 01:44 PM
