Running Lights 3/4 Inoperable
Results 1 to 4 of 4
    Junior Member aktw200's Avatar
    26
    I just noticed that 3/4 running lights are outon my '07, only the frt rt works. All blinkers work fine, just no running lights. Will one of you electrical gurus please tell me which wires power the running lights. I'm sure it's probably a connector somewhere, but a little help would be nice. Thanks in advance.
    2007 TW200, Café Shield, Rear Cyclerack, Ricochet Skid Plate.
    Desert, SoCal
    7,369
    I'm not sure which 3 running lights you're referring to. If you mean the turn signals, only the 2 fronts function as running lights, and in the rear only the tail light should be lit.
    (We already solved 2/3 of your problem right there. Ain't we good?)
    Check the filaments in the bulb first, then look for corrosion in the socket, then follow the 3 wires into the harness near the steering neck and make sure they're connected.
    Member Lil Foot's Avatar
    Peoria, AZ
    32
    Yup, what he said.
    26
    Quote Originally Posted by Lil Foot View Post
    Yup, what he said.
    Yea, the turn signals. I did check the filaments and switched bulbs yesterday. Only the right side stayed on, but both blinkers worked, still the left side running light no worky. I did fiddle with a connector behind the headlight and got it to work sporatically; then I had to go to work. Thought I'd start it in the morning and re-check the connector, but lo and behold the battery was dead. Yes, I did shut it off yesterday afternoon and took the key out. Aarg. Got it on a trickle charger this evening.
  1. Got her running !
    By trailway in forum General Discussion
    Last Post: 03-16-2013, 10:54 PM
  2. got my tw running
    By dantilghman1 in forum Technical Help
    Last Post: 01-17-2013, 07:04 AM
  3. Getting my TW running
    By caseyb in forum Technical Help
    Last Post: 04-29-2012, 04:44 PM
  4. need help getting "new" 89 running
    By bpiersall67 in forum Technical Help
    Last Post: 03-14-2012, 04:38 PM
  5. Rear running lights
    By Sharpline in forum Performance and Customization
    Last Post: 08-17-2010, 06:34 PM
