Oil Leak
Results 1 to 4 of 4
Thread: Oil Leak
    Junior Member Mike Mecredy's Avatar
    Jul 2011
    Rupert Idaho
    26
    My 1991, leaks oil from the upper part of the left engine cover; the same cover that the sprocket is under. I went to take the cover off and take a look and the thing is full of oil. Is this normal? It seems that should be dry being the sprocket access. (I don't have a manual, but I guess I should get one)
    -mike
    918
    You can go buy a manual, or download the FREE manual here... https://tw200forum.com/index.php?/for...echnical-help/...it's the 6th thread down. Recognize the 10th thread down?
    Yes, oil in there is normal.
    Sold bike.
    Jul 2011
    Rupert Idaho
    26
    thanks
    Ephrata, WA
    1,125
    The TW's engine cover and sprocket cover are one in the same. Most dirt bikes will have a separate engine and sprocket cover which allows one to remove the front sprocket without having oil drain everywhere. It should not leak however.
    1990 TW200
  1. Oil Leak
    By ldw72120 in forum Technical Help
    Last Post: 02-25-2013, 08:49 PM
  2. Oil Leak
    By Senior Dirt Dog in forum Technical Help
    Last Post: 08-03-2012, 09:48 PM
  3. oil leak from where
    By jerz006 in forum Technical Help
    Last Post: 07-07-2012, 06:00 PM
  4. Oil leak...
    By xdac in forum Technical Help
    Last Post: 10-27-2011, 12:32 PM
  5. Oil Leak
    By B-dub in forum Technical Help
    Last Post: 08-09-2011, 01:19 AM
oil leak tw200
tw200 drive sprocket leaks oil
tw200 oil leak
