help with fork caps
Results 1 to 5 of 5
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    342
    I can not break the front downtube top caps loose. using a 19mm socket and a 14inch heavy duty craftsman wrench. Its not reverse thread is it? Downtubes still on the bike. Any suggestions. (2006 no corrosion visible)
    Dusty
    Frosty Hollow
    13,046
    My caps were not reverse thread. Just normal thread. Mine too were difficult to remove. One time I hit the end of the ratchet handle with a hammer to loosen the fork caps, and you can see there might be a problem with that. Last time I used an electric impact wrench which was much safer and did the job real quick. But yes they are pretty tight. O-Ring gasket and fork spring tension probably have something to do with it being snug.
    Ephrata, WA
    1,125
    Make sure you loosen the top pinch bolts first. My top cap bolts were tight, but it didn't take too much effort to loosen.
    1990 TW200
    Oct 2010
    SE Michigan
    342
    Quote Originally Posted by Rainman View Post
    That was it. Got it loose. Wow, that should have beeen obvious! Thanks for the quick repy!
    I've had to lower the triple about 2 inches below the cap, tighten the bolts, then use a 1/2-inch Craftsman hand impact and impact socket to break fork caps loose.
  1. STUCK FORK CAPS
    By AFISHALBIZ in forum Technical Help
    Last Post: 11-27-2016, 09:35 AM
  2. WTB 2001-newer front fork legs/lower fork legs/front wheel
    By jeadra in forum TW200 Classifieds
    Last Post: 05-06-2013, 01:04 PM
  3. New TW fork
    By bikerjosh in forum Performance and Customization
    Last Post: 05-17-2012, 05:22 PM
  4. 06 fork swap to 98
    By titanium in forum Performance and Customization
    Last Post: 04-14-2012, 07:07 AM
  5. Put on your Thinking Caps
    By Petrus in forum Off-Topic
    Last Post: 08-20-2010, 11:27 PM
