What "should" be done at 3500 miles?
Results 1 to 10 of 10
    Junior Member Topo's Avatar
    Jul 2011
    28
    I know there's some info in the manual about recommended servicing, but I wanted to ask, from a real world experience standpoint, what are the "must do" servicing needs at this mileage. Of course, this is beyond the obvious regular oil and filter change.
    thanks
    866
    The only real "must do" is to check the valve adjustment. You mentioned the oil and filter. This is also assuming you've been keeping an eye on the chain and sprockets on a regular basis, and have been servicing the air filter as needed.
    With that said, it doesn't take a whole lot of time to check everything.
    Lower Rio Grande, New Mexico
    1,702
    Checking air pressure in the tires weekly if not everytime you ride is a good habit. A low tire will make the bike corner and handle completely differently. A good go around the bike with allen wrenches, screwdriver, and hand wrenches is also wise to keep from loosing things like licence plates, helmet locks, and other things that wander when the fasteners vibrate loose. Watching that chain condition and tension is also important to not breaking or locking up a chain (not nice at highway speeds). Know your bike and it will serve you well. Ride on. Tom
    Central New Mexico
    Devon, England.
    614
    When you have done all the checks and adjustments don't forget the most important thing.
    Go for an extended "test" ride.
    918
    +1 on the above recommendations, you could also...
    Check battery water level.
    Give the zerks a good shot of grease.
    Sold bike.
    Drum brake bikes have maintenance needs listed on pages 3-1 and 3-2 of the Service Manual.
    Disc brake bikes have maintenance needs listed on pages 18-20 of the Supplement.
    If it's listed, do it.
    Jul 2011
    28
    Thanks...don't think I'm up to the task of a valve adjustment...but will work on all the rest.
    918
    Quote Originally Posted by Topo View Post
    It really isn't hard, you should try it. It's nothing more than a nut and bolt and a measurement. There's more risk in doing an oil change as owners are frequently given the wrong oil filter (without the holes) from the part supplier, thereby unknowingly allowing their bikes to run without proper oil flow.
    Sold bike.
    Jul 2011
    28
    Quote Originally Posted by pgilles View Post
    Well then...that *does* sound do-able. Thanks. I'll do a little searching for the how-to.
    I found out about the right filter to use before I changed it the first time. Time to do that again before this weekends trek to the Sierras.
    Desert, SoCal
    7,369
    Post up a location. Odds are someone will offer to help you muddle through your first go-round.
  1. 10,000 miles
    By cptrout in forum General Discussion
    Last Post: 07-01-2013, 10:51 PM
  2. Bone Stock TW 200 500 Miles...YES 500 Miles
    By joedirt1970 in forum TW200 Classifieds
    Last Post: 06-28-2013, 05:59 PM
  3. First 300 miles
    By rhypayne in forum General Discussion
    Last Post: 01-29-2011, 06:30 AM
  4. How many miles on your TW?
    By crossent in forum General Discussion
    Last Post: 12-15-2010, 12:35 PM
  5. Replies: 12
    Last Post: 12-03-2010, 07:58 PM
rodneyreed
