wiring problem
Results 1 to 10 of 10
Thread: wiring problem
    Junior Member mikeparr123's Avatar
    Jul 2011
    8
    hi i have a 1988 yamaha tw200 the wiring is pretty bad and i cant seem to find a wiring diagram anywhere the only time i got close was the tw125 but it wasnt the right year.so what im wondering is is there any othe years that have the same wiring? or could someone post one for me i love my tw and i want to restore it but all that is left is the wiring thanks
    918
    Check the manual...
    Sold bike.
    540
    this is color 1987 I came across. save time from trying to figure all the color codes
    Jul 2011
    8
    don't quot me on this but isnt the wiring in the 1987 different? thats what i heard
    540
    by chance did you down load the manual that PGILLES reference above, look at the wire diagram, study it and compare the 2
    Jul 2011
    8
    yes i downloaded it and i got everything hooked up and i can even hear the relay switch over but my starter motor doesnt turn at all any suggestions? im going to hook my voltimeter up and see if its even getting power.
    918
    Is the battery good? Is it charged? Are the connections all tight?
    Did you try jumping the starter relay/solenoid? Just because it's clicking doesn't mean it's actually making the connection inside. Jump it with a heavy gauge wire or a screwdriver, a small wire will get really hot on your fingers if you hold it there too long. If you don't have a heavy gauge wire or screwdriver to make a jumper out of, you can remove the starter wire from the solenoid and touch it to the battery wire at the solenoid to make the starter spin.
    If the starter tries to spin, the relay/solenoid is bad or the trigger wiring to it is not providing enough juice. If it doesn't spin you may need a new battery, a good charge, a better ground connection, or a starter.
    Let us know the voltmeter readings.
    Sold bike.
    540
    Quote Originally Posted by miker View Post
    just to clairify, when you say you can hear the relay click- is it the little click when you turn the key or the big click when you push the thumb starter button..
    also can you use the kick starter to start it.
    Jul 2011
    8
    well first off i arched the positive on the battery to the frame and it was pretty powerfull i also tried doing the schrewdriver hotwire thing to but nothing.and let me clarify about the relay im not talking about the start relay im talking about the engine cut off relay the person i got it from said that the main switch was bad but seeing as the engine cut off relay clicks and thats hooked up to the main switch tells me that the main switch is in fact working.I geus im just going to have to go through the electric start circuit again because today i notice that my side stand switch is not hooked up and that is included in the circuit. i would use the kick start and just forget the whole electric start thing all together but i cant find a kick start peddle for that year anywhere is that one of those things where you can use any one you want?
    918
    Any tw200 or bw200 kicker will work from any year. The bw200 shows same part number as the tw200.
    Is arching against the frame how you tested the battery???
    Did you jump the engine cutoff relay or the starter relay?
    Go over the whole bike and fix according to the manual. Sounds like were fighting too many unknowns right now.
    What were your voltmeter readings? That'll tell you what's working.
    Sold bike.
  1. wiring a TW from scratch
    By adavis in forum Technical Help
    Last Post: 07-22-2013, 05:49 PM
  2. Head Light Wiring
    By chasejamy in forum General Discussion
    Last Post: 08-03-2012, 03:48 PM
  3. 87 Project and wiring question
    By Johnywad in forum Performance and Customization
    Last Post: 12-07-2011, 12:54 PM
  4. Need Wiring help, ground up
    By wdaloz in forum Technical Help
    Last Post: 09-30-2011, 01:26 PM
  5. New Ignition wiring
    By disgruntled in forum Technical Help
    Last Post: 06-28-2011, 02:29 PM
1988 yamaha xt600 wiring diagram
1995 trailway 200 wiring schematic
how to connect a different ignition key switch in yamaha tw1994
trail wagon runabout tw200 4x2 wireing diagram
trail wagon tw200
trail wagon tw200 runabout wiring diagrams
trailwagon tw200 runabout wiring digrams
tw200 wiring diaghram
tw200 wiring diagram
yamaha tw200 wiring diagram
yamaha xt 200 wiring diagram
yamaha xt 600 wiring problems
