Just picked up a 2006 TW. Almost right away, the carb started leaking gas steadily from the float bowl air inlet. Any ideas so I don't have to spend a fortune at a dealer?
You can probably do it, but if you are a total nubie with carbs, I'd suggest a friend help or you invest $50 to have it done by a professional. IMHO. Good luck. Tom
Oh, in the meantime always turn off that petcock when you are not on your bike. When the engine is running it will probably consume enough fuel to keep up with the leak. T.
Related Threads
TW200 Forum
532.4K posts
23.4K members
Since 2010
